Torque Pro App adapter question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-24-2014, 02:39 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Which adapters are you guys running? I just made the switch from an Iphone to the Nexus 5 so I'm pretty much obligated to get the Torque app, but I'm not sure if I buy a cheapo adapter or spend some $$.
Post up which ones you guys are using and what luck you've had with them please!
Thanks in advance
Also... theres no chance of me using my adapter from the AE proline to my phone is there? Via the USB
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #2 of 13 Old 01-24-2014, 04:35 AM
johnnybgood's Avatar
Quoted: 78 Post(s)
$9 el cheapo china made ELM327 mini bluetooth adapter here. Been working fine the last few months. I've left it plugged in all night more times then I've planned but it's been fine.
Sometime's i'll leave the adapter in and app running when I shut the truck off. Then when I restart the truck, if I don't let the app sync with the blue tooth before cranking, it wont read anything correctly except the coolant temp. No matter what I do.. it wont read right until I shut the engine off, take the key out, unplug/shutoff the app, then restart and redo the adapter/app.
johnnybgood is offline
post #3 of 13 Old 01-24-2014, 06:14 AM
I purchased a cheap one off ebay (can't remember exactly which one....) and it would not work on my truck. Worked on every other vehicle I tried, just not my truck. I researched a little and found that some of the cheap ones have trouble reading Fords. I would spend a little more and get a good one!
jphillips is offline
post #4 of 13 Old 01-24-2014, 06:22 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I got this one, the cheap chinese ones are hit and miss from what i heard, its better to buy the right one first then have to buy the cheap one first then have to buy this one the second time
http://www.amazon.com/gp/product/B005NLQAHS/ref=oh_details_o02_s00_i01?ie=UTF8&psc=1
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 13 Old 01-24-2014, 06:31 AM
Quoted: 78 Post(s)
So which did you end up buying?
If you don't have another one in there and working, then maybe it's your truck, and the obd port isn't working?
post #6 of 13 Old 01-24-2014, 06:32 AM
The one shown in the link above looks exactly like the one I have that will not work. Perhaps I just got a bad one? It works on everything except my Ford.
post #7 of 13 Old 01-24-2014, 06:38 AM
I have not bought another one yet. I guess it could be a problem with my the port on the truck, but it works with other scanners I have tried. I also have a Superchips tuner that uses the port and it works fine. From everything I read, I believe it is the adapter.
post #8 of 13 Old 02-07-2014, 03:22 PM
Has anyone had trouble with readings? My coolant temp reads regular but my oil temp reads like its missing the "1" in front of the number
acydzik is offline
post #9 of 13 Old 02-07-2014, 06:29 PM
I have the BAFX adapter and also run an Edge evolution tuner. The adapter works fine on our VW but would never connect to the F350. I unloaded the Edge tune from the truck and it connected just fine after that. Loaded the tune back and it wouldn't read it again. So I'm planning on a PHP Hydra chip soon because it looks like the Bluetooth adapter works just fine for the guys who run it.
99 F-350 Supercab Short Bed, 4x4, 6 speed, 180k miles, Edge Evolution, Diamond Eye 4" SS, AFE intake
scottrepos is offline
post #10 of 13 Old 02-07-2014, 08:55 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
I keep searching the Torque Pro app on my ipod touch but dont find anything. I get some other apps like it but nothing torque pro. or is this a non apple thing?
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
