driver side whistling sound - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-23-2014, 05:20 PM Thread Starter
I noticed the other day when pulling my trailer and pulling a big hill, that when the turbo seemed to reach full boost there was a loud whistling noise that sounded like it was coming from the driverside of the engine compartment under the dash. I'm fairly new to diesel pickups so was wondering if this is normal or if I have a leak or turbo issues? It only does it when I seem to really get on it. Don't have gauges yet.
mashthegas is offline
post #2 of 9 Old 01-24-2014, 04:41 AM Thread Starter
Any body have any ideas where to start?
post #3 of 9 Old 01-24-2014, 07:42 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 393 Post(s)
Check your up pipes where they Y up into the turbo housing see if you have soot around them. There is a donut gasket on each one. Under a load they can make noise
@loxdce
LoxDiesel is online now
post #4 of 9 Old 01-25-2014, 05:59 AM
blue99stroker's Avatar
Quoted: 270 Post(s)
you getting compressor surge?
you can look it up on youtube
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 9 Old 01-25-2014, 05:28 PM Thread Starter
It doesn't sound like turbo surge, it's more of a high pitched, loud whistle, and I have no loss of boost or power.
post #6 of 9 Old 01-25-2014, 05:49 PM
timmyboy76's Avatar
remove the intake and check the compressor wheel and housing for marks.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 9 Old 01-26-2014, 06:27 PM
Do you have an aftermarket intake on the truck? If so they make more noise than stock.
Mattyneil is offline
post #8 of 9 Old 01-27-2014, 03:53 AM
scagle1's Avatar
Completely different vehicle but -
On a semi I had I developed a crack in an exhaust manifold , when building boost and pulling hills that crack created a LOUD whistle , embarrassingly loud ! Not saying it's your problem but definitely sounds as if you have a large volume of air escaping through a small something to create the whistle effect.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #9 of 9 Old 01-28-2014, 06:51 AM Thread Starter
I do have an afe intake. Haven't been able to find any obvious leaks. Will check turbo and housing when it warms up again. and report back.
