Arp head studs question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-23-2014, 05:04 PM Thread Starter
How much psi boost do I need head studs I wanna run a s366 non waste gated
Right now my set up is a 01 f350 crew cab long bed sct live wire with innovative diesel tunes, riff raff boost fooler, diamond eye 5 inch exhaust no muffler, cold air intake, wicked wheel in turbo if I just switched out the turbo would I need head studs also what can I do to maximize boost out of my stock turbo
Dirtydiesel9 is offline
post #2 of 4 Old 01-23-2014, 08:08 PM
Joel's Avatar
Quoted: 10 Post(s)
I think the gains of that turbo wouldn't be fully realized unless you upgraded the injectors as well.
There are many factors when it comes to the necessity of head studs, but to keep it simple say 40psi or so to think about adding studs.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 4 Old 01-23-2014, 08:46 PM
7.3 no studs, 6.0 studs
sean andreano is offline
post #4 of 4 Old 01-23-2014, 08:51 PM
CSIPSD's Avatar
You are no where near the need for a T4 turbo set up... I would not suggest the 366 to begin with, but first I would pick a HP goal...
There would be little if any gains with the turbo swap, it would more then likely spool slower then stock.
Very simplistic...
Having to run studs has more to do with cylinder pressures, not boost.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
