What do you monitor with your cts? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-23-2014, 03:45 PM Thread Starter
nuthinbutfords's Avatar
Quoted: 5 Post(s)
Couldn't exactly find this in the search function. Just received my edge back from edge I set it up to monitor engine temp (big display on left), egt (bottom middle display), and trans temp (right side large display. In the bottom left corner i have exhaust back pressure, bottom right is my boost. Any thoughts on this? Is there something more important i should be watching than one of those items?
Thanks Travis.
E99 F250
BDS 4in lift with Fox shocks
20x12 962's on 35in Trail grapps
pro comp ladder bars (want something better)
DP tuner F5 chip
6637 intake
5in MBRP exhaust with 7in tip
05 Harley Davidson front end
Retro Solutions 55w 5k hids
And hopefully more mods to come
nuthinbutfords is offline
post #2 of 5 Old 01-23-2014, 03:55 PM
oil temp maybe, I run what you have plus oil temp.
sean andreano is offline
post #3 of 5 Old 01-23-2014, 05:32 PM
kbragg430's Avatar
You could always have icp and duty cycle up there as well. I have my cts set up to show 8 pids at once. Not as cool looking but more to monitor.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #4 of 5 Old 01-23-2014, 08:03 PM
Joel's Avatar
Quoted: 10 Post(s)
I monitor corrected speed, oil temp, ICP, IPR, EBP, and I moved the IAT sensor to behind the front bumper so I can use it to see what the temperature outside is.
Also nice to be able to pull codes on the go.
Gauges for EGT, boost, tranny temp, fuel pressure, volts.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 5 Old 01-23-2014, 11:01 PM
Macon's Avatar
Let's see if I can get them all by memory.
ICP
IPR
EOT
TFT
Boost
EGT
Corrected speed
And a variable.
The variable I use to monitor everything else that's not important, but matters to me at the time. Right now I'm watching IPW, I think. Just curious about what it does. This is the slot I use for random bs, but also the one I pay attention to most because I change it so often. The rest of them just interest me in "typical" numbers. I don't care about it until I see something I'm not expecting.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
