- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Sigh...Ran out of fuel and can't get truck to start now!
Hey everyone,
So this morning I was driving to the station for some fuel and the truck ran out "on the way there" This had happened to me once before but I easily got it started last time. Now I know you're thinking "well you dummy why did you let it run out of fuel?" but the problem is the gauge said I had a little over 1/8 of a tank and no low fuel light on. I thought I was perfectly fine (which I thought last time as well ).So I'd like to know what the problem may be with the gauge for one (sending unit?) and two: How can I get my truck to start again since it ran out. I killed the battery today from cranking it over so much. I put in 3 gallons of fuel (only have a 1 gallon can..I just love making trips back and forth from the station). Is 3 gallons enough? I cycled the key turning it on for 20 seconds and then off and repeat for about 5 mins and still no luck. Any special tricks out there? Thanks, Mark |
| Sponsored Links |
Thanks for the replies. I was under the impression you could prime it as well (but I don't know how) plus the manual just says keep on crankin' until it starts. Another 5 trips to the fuel station is what I'll have to do I suppose but I'm going to try diesel dans idea first and see if it works (that is, after I get my battery recharged!) |
When I drained my fuel bowl to change the filter and replaced the spin on filter on the rail, i turned the key in and waited for the pump to cycle off (maybe 30 seconds) I did this with the drain open till fuel started to flow to the jug on the ground. then closed the valve and cycled the key a few more times till i stopped hearing bubbles in the tank from the return
Okay well I suppose I'll get the battery charged/jumped and try to cycle the key again. I know last time this happened I put 2.5 gallons in from a can and got it started no problem and it was super empty that time (this time I shut it right off). Perhaps the battery dying wasn't allowing the pump to work efficiently? Now if I could just find those damn jumper cables lol.
| Sponsored Links |
