EBP Sensor/Tube Cleaning and MPG gains? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-21-2014, 06:45 PM Thread Starter
Quoted: 2 Post(s)
I am making a list of things to check/clean/replace on my new truck to try and get the best MPGs possible. I watched a video and read a few posts on cleaning the EBP sensor/tube and read that it can improve MPG.
Has anyone calculated the gains if there was an actual increase? Feedback is appreciated and thanks in advance!
winona78 is offline
post #2 of 15 Old 01-21-2014, 09:19 PM
Joel's Avatar
Quoted: 10 Post(s)
Little story for you;
I monitor EBP all the time. And one day it went from the normal readings of 0psi at idle to 25psi and just got worse from there as boost increased.
I happened to be about 12 hours from home at the time and was just hitting the freeway in the morning.
I got THE WORST mileage I've ever got on that trip. I didn't even calculate it because it was so bad and I already knew the issue.
I cleaned the tube AND replaced the sensor as soon as I got home and all went back to normal.
Now cleaning the tube is fine, but in my experience cleaning the sensor is a waste of time. Once it gets clogged the diaphragm inside gets buggered up and cannot be cleaned.
Unless you have a way to monitor EBP don't waste your time cleaning the sensor
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
The Following User Says Thank You to Joel For This Useful Post:
winona78 (01-22-2014)
post #3 of 15 Old 01-22-2014, 05:24 AM Thread Starter
Quoted: 2 Post(s)
Thanks Joel... That definitely helps!
winona78 is offline
post #4 of 15 Old 01-22-2014, 07:59 AM
7.3LDriver's Avatar
Quoted: 5 Post(s)
So cleaning the tube only regains the mpg lost from the tube being clogged?
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
post #5 of 15 Old 01-22-2014, 08:07 AM
RPM Tim's Avatar
Eh? If the tube is clogged, it will cause poor mpg. If the tube is clean, it will read as intended.
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #6 of 15 Old 01-22-2014, 10:03 AM
Joel's Avatar
Quoted: 10 Post(s)
Yes that is correct, but only if the sensor is still functioning properly.
If the sensor "thinks" the tube is clogged it won't help at all to have a clean tube.
Joel is offline
post #7 of 15 Old 01-22-2014, 01:19 PM
blue99stroker's Avatar
Quoted: 282 Post(s)
last two tanks ive been getting about 12 mpgs, 2 mpg drop from before.
i just cleaned the ebpv sensor and tube.
the ebpv sensor was about clogged, and the tube was completely clogged!.
i just did a quick fix, sprayed some brake clean down the tube and forced air through it, it cleared up pretty quick.
then i just cleaned the sensor out, make sure you dont harm the diaphram when cleaning he sensor. now i should get my sudden 2 mph loss back. did i mention it was 12 mpg highway
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #8 of 15 Old 01-22-2014, 03:22 PM
Joel's Avatar
Quoted: 10 Post(s)
Blue99,
In theory you will get that mpg back, but only if the sensor is reading correctly. Hook up an edge insight or AE and make sure it reads 0psi at idle.
Joel is offline
post #9 of 15 Old 01-22-2014, 04:06 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
I agree here. Cleaning the sensor has never proven well for me, and most do more damage then good when trying to clean it.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #10 of 15 Old 01-24-2014, 05:17 PM
Prew32's Avatar
Quoted: 12 Post(s)
Send a message via AIM to Prew32
Blue99,
If it reads more than 0psi at idle the sensor is bad? I just cleaned my tube and sensor last weekend amd I just checked the EBP using my torque pro and i was getting like 15psi at idle
15 F350 CCLB 6.7 Many mods to come.....
01 F350 CCLB 7.3 6 Speed SOLD
Prew32 is offline
