00 vs 01 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-21-2014, 05:59 PM Thread Starter
balistic's Avatar
00 vs 01
sold my 01 a few years ago, now i have a 2000 (11/99),i see they bumped up hp in 01 but can't see any mechanical change. So if a guy installs an ecm from an 01 into his 2000 would it work and work it bump up the HP???
2000 ccsb auto, 4x4 269,xxx and still climbing on the original transmission. TS 6 position chip, aih delete, 4" BANKS exhaust, recon cab lights, cowl hood, useless zoodad mod, CTS Insight to monitor, boost fooler, Garret GTP38 turbo, Airaid cold air box, TDK prerunner protecting the front, the wonderful Stancor GPR, and all wrapped up in a beautiful black package.
balistic is offline
post #2 of 8 Old 01-21-2014, 06:07 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
there is no hp difference between 99.5 to 2003.
the idm's are all the same more or less from 95-03
a different pcm wont give you more hp.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 8 Old 01-21-2014, 07:47 PM Thread Starter
balistic's Avatar
actually several sites i have found show an increase from 235 in 99-2000 to 250 in 2001 for automatics
balistic is offline
post #4 of 8 Old 01-21-2014, 07:51 PM Thread Starter
balistic's Avatar
Power Stroke Diesel Timeline
balistic is offline
post #5 of 8 Old 01-21-2014, 08:07 PM
Quoted: 283 Post(s)
and it says the manual has 275hp.
the e99 has about 10-20 hp less because of smaller injectors (20cc less), smaller turbo and smaller hpop(15*).
99-03 all have about 210hp to the WHEELS.
trans tuning is different between pcm codes but the hp levels are the same.
if you swap a later model pcm in you will possibly get different trans tuning, (pmt1 is the code everyone likes), 01's also had the weakest tranmissions.
and if you get a chip it will be the same for late 99-03. no extra power to be squeezed out of a newer truck
post #6 of 8 Old 01-23-2014, 03:15 PM
tune it for hp
sean andreano is offline
post #7 of 8 Old 01-24-2014, 09:13 AM
There is definitely a difference in the PCM calibrations between 2000 and earlier versus 2001 and later models of automatic transmission equipped Super Duties.
Y2KW57 is offline
post #8 of 8 Old 01-24-2014, 09:23 AM
CSIPSD's Avatar
There is no reason to swap PCM's... Complete waste of time. If you want to add a little HP then get the PCM flashed or use a Penny pincher chip from Powerstruck.
POWER-STRUCK, osgood indiana, performance tuning
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
