02 excursion cold start - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-21-2014, 06:26 PM Thread Starter
aaklingler's Avatar
My excursion doesn't start when below freezing without being plugged in. I checked the glow plugs and they are good. What else could cause it to not start cold?
1996 F350 CC 4x4 auto 196k DIY intake
2002 Excursion 4x4 255k 160/80 66mm gtp38 intake and exhaust
aaklingler is offline
post #2 of 21 Old 01-21-2014, 06:47 PM
Worn injectors can give the same symptoms of bad glow plugs.
Also test cranking rpm. You could get lucky and have a weak battery or dragging starter
Power-Struck dot com
POWER-STRUCK is offline
post #3 of 21 Old 01-21-2014, 07:08 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
bad glow plug relay.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 21 Old 01-22-2014, 04:22 AM Thread Starter
aaklingler's Avatar
I'm pretty sure my batteries and starter are good. I have the new style glow plug controller, how do I tell if it is bad?
post #5 of 21 Old 01-22-2014, 05:13 PM
heisman01's Avatar
Quoted: 52 Post(s)
Switching over to 10w30 helps a lot. Get a western plow relay to replace your stock one $20 and it works great on mine.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #6 of 21 Old 01-22-2014, 05:28 PM Thread Starter
aaklingler's Avatar
I don't think I can use the plow relay, can I, I have the new style module? I don't have any trouble starting my 96 truck.
post #7 of 21 Old 01-22-2014, 05:31 PM
Unplug the EOT sensor then cycle the glow plugs on and measure the voltage drop between the two large terminals on the relay. On a good relay the voltages should be within a few tenths of a volt of each other
post #8 of 21 Old 01-22-2014, 05:39 PM Thread Starter
aaklingler's Avatar
I have the same module as the 6.0 has can I still do that?
post #9 of 21 Old 01-22-2014, 05:41 PM
No you would have to use a scan tool or a clamp on DC ammeter
post #10 of 21 Old 01-22-2014, 05:44 PM Thread Starter
aaklingler's Avatar
I have a snapon mtg2500 with a 2000 cartridge. Can I use that on my 2002?
