- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
NEED HELP i broke something, but not sure what.
Ok heres the issue, I let some friends help put my amp and new cd player in, i put cd player in tested it it worked great, ten they ran rca and remote wires and hooked up system. I went to turn on radio and when i turned key to acc the 4x4 and low gear light was on and that pump and the inner fender behind pass batt was buzzing away for like 2 min, and radio wont work. i knew i should have done it myself
but hey the "knew what they were doing" please help its supposed to be my work truck. the truck does still start
| Sponsored Links |
Ok first off how did you install the radio, remote power to the amp. Did you use an install kit for this or did you hack up the wiring harness. Did you hook the remote power wire to the radio or did you find a key hot wire under the dash and tap into that. Power to the amp did you run a wire directly from the battery should be at least 10 gauge wire for this. The RCA's is not the probelm. |
Does your AC only blow out the defrost? You said the vacuum pump does shut off right? Turn the switch to 4x4, 4 low, and 4 high than turn it back to 2 wheel high does the light shut off? This is very strange, have you checked all fuses?
NCH |
| Sponsored Links |
