Old 10-08-2008, 05:00 PM
ROLLTIDE72 ROLLTIDE72 is offline
Exclamation Fuel Leak
Ok today i went out to get in my truck and noticed a smal drip on my driveway. Well I climb under and it is fuel. I couldnt figure out where it was comign from so i wiped everything clean and let it run for about 5 min. Nothing dripped well drove to work and cut the truck off and it is dripping steady. I check the valley and i can see a little puddling. What do I need to do to figure out where its coming from. Seems like every thread I search has a different answer.
Old 10-08-2008, 05:04 PM
ford99PSD ford99PSD is offline
check your fuel bowl drain. i have heard of it leaking and puddling up in the valley of the engine.
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
more than likely the drain valve onm the bacxk of the filter housing , you can replace the o-rings , i usually recomend the valve to be replaced , ive seen valves cause problems to
Old 10-08-2008, 05:10 PM
I am really busy right now and I need to leave town for bussiness is it going to hurt to drive it or if i take it to the dealer ship does anyone know what kind of money to replace the drain valve.
Old 10-08-2008, 05:14 PM
wont be cheap probably , 150 to 200 dollars , the valve is like 60.00 retail , will not hurt anything to drive , just gonna leak
Old 10-08-2008, 05:16 PM
Thanks I hate to let it leak liquid gold and I had rather fix it my self I feel useless if I just drop if off and tell them to fix it.
Old 10-08-2008, 05:22 PM
toddy toddy is offline
OperationSmile.org
Its a pretty straight forward repair. Mine is leaking so I have all new fuel orings on order. I have lost 3mpgs since this started fyi
Old 10-08-2008, 05:24 PM
Is there an O-ring kit that has all the ones you need and any special fuel line tools needed.
Old 10-08-2008, 05:26 PM
you can buy the o-ring kits on ebay im pretty sure , cheap, no special tools , a 27 torx bit socket and 1/4 inch drive ratchet and about 15 minutes of your time
Old 10-08-2008, 05:30 PM
OperationSmile.org
Here you go. I spent 28 bucks got priority shipping and got pedistal orings, fuel kit and fuel line sleeves.
Replacement O-rings for Diesel Engines
