Old 10-08-2008, 01:01 PM
m109a3uk m109a3uk is offline
Poblems with 2003 7.3 f350
Hi Guys
Couple of problems I have the engine warning light on all the time I have scanned it with an obd scan tool and found the following codes P1280(icp range low) P0237(Turbo sensor low input) and P1670(EF feedback signal not detected) Tried to reset but wont go out checked that the connection to the ICP are good and it has its 0.5volt. Buzz test done and passed.
Anything you guys would recommend should I order a new ICP?
What should i see at the ICP?
Also today the batterys were down(needs new ones truck not used very much!!!) when I went to start the gauges all went up and over! Boosted the truck and now the ABS light is on
Last problem I'm in the UK
Tony
