Old 10-07-2008, 08:29 PM
FL_SmokinPSD FL_SmokinPSD is offline
Probably a stupid question but what battery do i use for an amp?
I dont know if it matters, but dont want to mess up my truck. I have a 2500w amp and im not sure which battery to hook it up to please help a newb out.
Thanks yall
Old 10-07-2008, 08:31 PM
flowmasters40 flowmasters40 is online now
Send a message via AIM to flowmasters40
i hooked up to my driver side but i dont think it matters
Old 10-07-2008, 08:32 PM
ford99PSD ford99PSD is offline
hmm i dont think it matters then, mines on the pass. seems to do fine for me
forddieseltweek forddieseltweek is offline
I honestly dont think it matters...
Old 10-07-2008, 08:34 PM
fsas fsas is offline
I believe both batteries are wired together anyhow...not sure if they're in series or parallel...I would think parallel.
Old 10-07-2008, 08:50 PM
thats what i figured but wasnt sure, i know in the manual it says to hook jumper wires to one side only so i thought id ask, cuz i want to hook it to pass side. Yall are great here 4 replies in 10min THANKS GUYS
Old 10-07-2008, 08:53 PM
any time welcome to the org
Old 10-07-2008, 10:25 PM
ok next question, where on the pass side did you run the wres through the firewall?????
Old 10-07-2008, 10:28 PM
TxPSD9673 TxPSD9673 is offline
well cant help ya there but i hooked mine up to the drivers side and drilled a hole for the power, put in a gromet, and sealed it up.
Old 10-08-2008, 06:38 AM
tubular031 tubular031 is offline
the 2 batteries are wired in parallel to provide twice the capacity but keep the volts at 12. if they were in serial, you would only get 1 bat worth of capacity and 24 volts.
wire into which ever bat makes it easier for you. I have things tied to both batteries. just make sure you put a fuse as close to the bat as you can! as in inches or less, NOT feet from the bat.
