Addressing 7.3 weak points .... - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 20 Old 01-20-2014, 07:01 AM Thread Starter
ChiefRocka's Avatar
Ok, I just picked up the truck ... a clean '02 F250 CC Lariot 167k miles
Is there anything I should look into swapping out for aftermarket as far as reliability goes ?
I know the 6.0 needs alot, but what about this guy ?
Fuel system ? Oil cooling ?
It has an aftermarket exhaust already
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 20 Old 01-20-2014, 07:13 AM
alaskan155's Avatar
Quoted: 60 Post(s)
the intercooler boots, the oil from the pcv on the engine vents to the intake deteriorating the boots.
i replaced mine with riff raff boots, and keep a spare CPS sensor in the glovebox with proper tools to replace it,
if you plan on keeping it a while and it has green coolant in it either install a coolant filtration system and maintain it(plenty of threads on here) or else it will cause cavitation in these motors or run a cat rated antifreeze such as rotella ELC(what i run)
and lastly
Welcome to guzzle's Stancor GPR replacement Mod Web Page the stancor glow plug relay or western plow relay from napa,
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
The Following User Says Thank You to alaskan155 For This Useful Post:
ChiefRocka (01-23-2014)
post #3 of 20 Old 01-20-2014, 10:07 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
a better trans cooler helps.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
post #4 of 20 Old 01-20-2014, 06:56 PM
hansel's Avatar
Quoted: 95 Post(s)
First off Congrat's on the purchase
I would change all the fluids, oil, rear gear lube, change the fuel filter, and flush some new coolant through it. I have a coolant filter that I installed and I change my coolant every 60,000 miles and ad the SCA every 15,000 miles and I have had no coolant issue's (yet) with the mileage it's not sure how much longer the transmission is going too hold up, but if you plan on towing anything install the 6.0L cooler. My truck has over 253,000 miles and I keep it well serviced and other than a tranny at 194,000 miles it's been a rock solid truck, now the outside body needs some TLC
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
The Following User Says Thank You to hansel For This Useful Post:
post #5 of 20 Old 01-20-2014, 08:33 PM
As long as you stay on top of the maintance and "replace things as they creep up on you" do not wait till they fully fail (this can create a ton more problems sometimes), the only weaak link is the transmission (R100) if an automatic. but once you ever have that fixed with the "revisions for longevity" these tend to be the best of the ford powerstroke breeds.
Would be an unstoppable combination if you could mate a newer torq-shift trans to the 7.3 powerstroke
hnbperformance is offline
The Following User Says Thank You to hnbperformance For This Useful Post:
post #6 of 20 Old 01-20-2014, 09:35 PM
Macon's Avatar
CCV delete
Spare CPS on hand
CAC boots are something to consider. I haven't had a problem, but I'm lucky.
GPR relay
Tunes from a good tuner - they help the trans, and make the truck fun
With the tunes, intake and exhaust are good ideas.
6.0 trans cooler
There are lots of other things you can do for funsies, but that's the short list of things to aid in longevity.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
The Following User Says Thank You to Macon For This Useful Post:
post #7 of 20 Old 01-20-2014, 10:12 PM
Eco Taxi's Avatar
Everything listed above then hutch and harpoon mod and look at a fpx and fpx
https://www.strictlydiesel.com/p-268...sover-hpx.aspx
https://www.strictlydiesel.com/p-266...-pump-kit.aspx
Fuel Rail Crossover? (FRx) - Riffraff Diesel Performance
Then maybe
http://www.dieselsite.com/wickedwhee...s-instock.aspx
Check out
Welcome to guzzle's Ford PSD Web Pages
SpringerPop's F-350
And there's many more threads online
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
The Following User Says Thank You to Eco Taxi For This Useful Post:
post #8 of 20 Old 01-23-2014, 02:23 AM Thread Starter
ChiefRocka's Avatar
and lastly
Looks like the boots have been replaced.
I plan on flushing the coolant, and will look into the better coolant.
So if I run the CAT rated stuff, I wont need the filtration system ??
It's a Cali truck, so the glow plug mod is N/A ?
John
post #9 of 20 Old 01-23-2014, 02:25 AM Thread Starter
ChiefRocka's Avatar
In addition too, or bypass the stock one all together ??
We use the frame mounted one's on all of our hotrods here In the shop.
Thought about the type with built in fan ??
John
post #10 of 20 Old 01-23-2014, 02:28 AM Thread Starter
ChiefRocka's Avatar
Thanks man ....
I plan on changing all the fluids. The rear diff cover is seaping, so that will be addresses soon.
What type of gear oil is required ?
What about the tranny fluid type ?
John
