Who runs a stock clutch with a TS chip? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-19-2014, 07:18 PM Thread Starter
AddictedOffroad's Avatar
Just curious how long your stock clutch held up with a TS chip installed?
Mods would be 6637 filter, exhaust, and standard TS chip on a 2003 7.3L, 2wd ZF6, stock injectors. I tow 10k-17K from time to time. The truck will have gauges as well.
Scotty
1999.5 F350 DRW, CC, LB, A/T, 7.3L. Bank Exhaust brake, 4" Exhaust, BD power Thruster II turbo, PHP Hydra
AddictedOffroad is offline
post #2 of 4 Old 01-19-2014, 08:08 PM
They usually hold up just fine.
all depending on driving style and clutch habits. Along with the possibility of fuel and oil leaks
Power-Struck dot com
POWER-STRUCK is offline
post #3 of 4 Old 02-16-2014, 09:12 PM
StrokinAlaska's Avatar
I run my stock auto with a TS 6, c.i.a, gauges, custom exhaust, water/method,ww2. No issues yet, but I only run in 50hp setting daily. Sometimes I get speedy Gonzales and do 100hp for a light to light, but never more, I did the 140hp but black smokes and is sluggish compared to the 100hp. Think I'm in need of Injectors,Hpop, fuel pump mod
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #4 of 4 Old 02-21-2014, 05:17 AM
DPTuner on 01 F250, and the stock clutch wouldnt hold it. Even the cruise control would over-rev the motor on a hill. I had to upgrade the clutch. I paid someone to do the clutch swap because I dont have anything strong enough to deal with the heavy tranny/transfer, and the shop which did the new clutch (South Bend) said the stock clutch was not worn or damaged in any way, it looked fine, no oil etc. It just didnt have sufficient clamping force to hold the additional torque.
alabamatoy is offline
