Beware of removing injector cups!!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-19-2014, 04:07 PM Thread Starter
Alright folks,
I rebuilt my engine and redid just about everything within the engine including the injector cups. I was going to wait and replace the injector cups while the heads where on the block. However due to impatience I decided to replace or at least pull the injector cups while the heads where on the bench. Needlessly to say after seeing what came out of the heads I'm extremely thankful none of the stuff in the pictures below fell in my new rebuilt block. Due to the tool shape I wasn't able to put the injector cups back in while the heads while they where on the bench but I at least got the cups removed before the heads where back on the block. So for those folks that are looking at replacing there injector cups be aware of what comes out of the heads when the cups are removed.
ID:	229754   Click image for larger version
ID:	229762   Click image for larger version
rayrayray01 is offline
post #2 of 7 Old 01-19-2014, 08:18 PM
alaskan155's Avatar
Quoted: 60 Post(s)
you have to drop a penny in the injector cup before using the tool to catch the shavings in the cup, also some grease will help to.
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 7 Old 01-20-2014, 01:00 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yeah if I were to do it a penny or dime dropped in flowed by a generous lump of grease
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 7 Old 01-20-2014, 01:21 AM
Rodslinger's B1TCH
is that brass from the injector cups themselves?
steve604 is offline
post #5 of 7 Old 01-20-2014, 07:19 AM
alaskan155's Avatar
Quoted: 60 Post(s)
its the shavings from the tap you use to pull the cups out, i know i did this job last may.
post #6 of 7 Old 01-20-2014, 08:51 AM
CSIPSD's Avatar
Oh no... a little bit of brass goes into the motor, out the exhaust and dumps on the side of the road... Wont hurt a thing no matter...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 7 Old 01-20-2014, 10:35 AM Thread Starter
There are some that would argue the fact about the motor getting hurt or not. All I know if some metal shavings got stuck between the piston and the side wall of the cylinder it wouldn't help the life of the engine. But either way, possible harm to the motor or not, I only posted this so others would be aware of what they are dealing with when they go to replace the injector cups. I didn't know about the penny trick until I posted this so as long as others learn from this post and can prevent possible harm to there engine; I have accomplished what I wanted to do.
