Tire HMMMM… masked early warning - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-19-2014, 05:28 AM Thread Starter
Watts7.3l's Avatar
As the title says my tires did a good job of hiding the warning sounds my wheel bearings were making. Not a big deal but its nice to know they are bad before they sound like I filled my diff with sand and grinded my ring and pinion to ****. Either way it was a quick job in the driveway for $225.00. I am constantly monitoring my truck and feel that i take better care than most but its easy to over look something like that. Moral of the story jack it up and check for wiggle and spin it for sound because they may be bad already and if you dont change them out…. THEY WILL GET YOU!
2001 F350 7.3l CC/LB 4x4
180,000
6" lift
36x15.5 M/T
20x12 Ulta wheels
Edge Evo II
6637
Muffler delete
2002 Excursion Limited 7.3l 4x4
91,000
Ford HD transmission
Watts7.3l is offline
post #2 of 5 Old 01-19-2014, 09:20 AM
79 toy's Avatar
What happens when one is bad? What's the worst that could happen tire fall off?
79 toy is offline
post #3 of 5 Old 01-19-2014, 09:26 AM Thread Starter
Watts7.3l's Avatar
Not sure…. If it goes for awhile it sounds really bad. But its the entire hub assembly that must be replaced because you can't service just the bearing. If i had to guess i would say that the wheel should not fall off. But some of the more seasoned gentlemen can chime in if I am wrong.
180,000
6" lift
36x15.5 M/T
20x12 Ulta wheels
Edge Evo II
6637
Muffler delete
91,000
post #4 of 5 Old 01-19-2014, 12:10 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Worsted case senario the bearing can get super hot on the highway and one of two things are possible at that point. It can weld itself solid, which will likely damage the spindle. Or I've seen one on a ranger get hot enough that it started a fire and the truck was a total loss.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 5 Old 01-19-2014, 06:16 PM
79 toy's Avatar
I see thanks I will jack the front end of my truck up and check them this week.
79 toy is offline
