coolant - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Vannnce
post #1 of 9 Old 01-18-2014, 06:29 PM Thread Starter
coolant
I need some help here. I was changing my thermostat,trying to fix my heater, the coolant was rusty brown looking so I did a flush, without looking up what type of coolant to use I went with what the guy at the auto store said to use, Prestone DEX-COOL® Extended Life Antifreeze/Coolant, orange. From what Ive read it sounds like I got bad intel. Do I need to flush again, wasting alot of money and time!
Thanks for any input
Allen
2002 f350 DRW 7.3
SMK-EATER is offline
post #2 of 9 Old 01-19-2014, 09:00 AM
Eco Taxi's Avatar
From my reading, you might want to change
Dex-cool in 2000 7.3
Check that out, maybe research other threads
I switched mine to zerex ELC - red in color - got at local Napa
Maybe someone else will speak up as well
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 9 Old 01-19-2014, 09:02 AM
Eco Taxi's Avatar
Uhhh....Did I make a mistake when I filled my Antifreeze??? - Page 3 - Ford Truck Enthusiasts Forums
Kyle
Eco Taxi is offline
post #4 of 9 Old 01-19-2014, 09:16 AM
Dex-cool for GM vehicles, not fords, going to be doing another flush buddy.
sean andreano is offline
post #5 of 9 Old 01-20-2014, 03:04 AM
kbragg430's Avatar
I used the zerex napa elc as well. But rotella, cat, international all have an elc that are used in these trucks. If you happen to have a dealer close. Or napa can order it for you.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #6 of 9 Old 01-20-2014, 05:49 AM
Vannnce's Avatar
Quoted: 13 Post(s)
i use shell rotella elc and have no complaints about it. would recomend it to other diesel/ 7.3 owners. i get it at the local international dealer but a lot of truck/rest/ gas stations have. kinda hit or miss there
alaskan155 likes this.
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #7 of 9 Old 01-20-2014, 06:42 AM
alaskan155's Avatar
Quoted: 65 Post(s)
x2 that dexcool is the wrong type
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #8 of 9 Old 01-20-2014, 06:48 AM
Custom Diesel Inc.'s Avatar
Agreed the Dexcool is for use in Duramax GM Rotella ELC is what I use in my 7.3 and had no problems.
Custom Diesel Inc. is offline
post #9 of 9 Old 01-20-2014, 06:13 PM
The only thing that I use in Ford diesel's is a yellow antifreeze (FORD PART NAME is VC7) it is a yellow Silica free antifreeze that is designed for high temperatures and dose not leave a scalely residue that can create hot spots on cylinder walls.
Learned about it when I worked for Ford back in 98/99 when they first came out with it. originally used in any trucks that were built in Kentucky -- usually the f250/f350 and excursion models is where I found it first.
Also if you have a Carquest anywhere nearby i is also made under the Mighty Name (VC7 antifreeze right on the bottle) other parts stores carry it too but they try to sell you universal antifreeze and they say it is the same because it will mix together ---
My best advise it to choose a very good antifreeze and stay with it no matter what the outcome of any parts replacement in the future, 1) because i don't mix brands of antifreeze -unless an emergency) 2) NEVER USE DEXCOOL --it is still the worst on the market does not mix with anything, even in an emergency, And GM is still stupid enough to use the ****
hnbperformance is offline
