TRUCK RUNNING SLUGGISH - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-17-2014, 04:16 PM Thread Starter
SNAKE76's Avatar
Loss of power through upper RPM range like its draging changed the IPR did the hutch mod, regulated return, Getting what i think is alot of injector rattleing and also replaced the ICP
SNAKE76 is offline
post #2 of 19 Old 01-17-2014, 07:02 PM
Joel's Avatar
Quoted: 10 Post(s)
What is fuel pressure at?
Also, fill in your sig so we can see what we're dealing with
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
The Following User Says Thank You to Joel For This Useful Post:
SNAKE76 (01-18-2014)
post #3 of 19 Old 01-18-2014, 06:16 AM Thread Starter
SNAKE76's Avatar
CHECKED IT THE OTHER DAY WITH AN OLD GAUGE AND READ 100PSI BUT I DONT THINK ITS RIGHT. I AM GOING TO GET ANOTHER GAUGE TODAY
FUEL BOWL DELETE,REGULATED RETURN,99.5 BELLOWED UP PIPES AND PETALSTOOL ON EARLY 99,HUTCH MOD,6.0 TRANS COOLER,MAP SENSOR ON HOT SIDE,6637 INTAKE,BANKS MONSTER EXHAUST,EDGE PROGRAM, NEW COMPRESSOR WHEEL,ICP,IPR,CPS
SNAKE76 is offline
post #4 of 19 Old 01-18-2014, 07:00 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
55-65 psi is where you want fuel pressure at.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
post #5 of 19 Old 01-18-2014, 07:25 AM Thread Starter
SNAKE76's Avatar
THANKS BLUE99STROKER. WHEN I FIRST INSTALLED THE REGULATER IT WAS AROUND 70 PSI I WONDER IF MY FPR HAS GONE OUT ON ME AND WILL THE 100 PSI CAUSE IT TO KNOCK LIKE HELL IN THE UPPER RPM RANGE AND HAVE NO POWER IVE DONE ALL THE WORK ON THIS TRUCK MYSELF I THINK IM OVER LOOKING SOMETHING THANKS FOR THE HELP GUYS ANY SUGGESTIONS WILL BE GREATLY APPRECIATED
SNAKE76 is offline
post #6 of 19 Old 01-18-2014, 09:35 AM
Joel's Avatar
Quoted: 10 Post(s)
I would suggest trying anothe gauge first. Imwas expecting a low FP issue, not a way to high issue
When was the fuel filter last changed? That is the cheapest and easiest place to start
Joel is offline
post #7 of 19 Old 01-18-2014, 09:40 AM Thread Starter
SNAKE76's Avatar
thats what im thinkin to the gauge is an old liguid filled that took a beating and lost some of its fluid one i had laying around the house. thanks ill check it this afternoon and let you know what i find out been a little while since i changed the filter
SNAKE76 is offline
post #8 of 19 Old 01-18-2014, 11:17 AM
Quoted: 247 Post(s)
knocking is usually associated with low pressure.
post #9 of 19 Old 01-18-2014, 03:34 PM Thread Starter
SNAKE76's Avatar
think ive got it fixed, new gauge PSI 100, spring in home made FPR bound up fixed it PSI around 57 doesnt seem to be rattling. Will up date yall in a day or so. THANKS FOR THE HELP GUYS
SNAKE76 is offline
post #10 of 19 Old 01-18-2014, 07:57 PM
Quoted: 247 Post(s)
i hope everythings good.
no diesel leaks anywhere from excessive pressure?
