cb turns off my truck when keyed - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-17-2014, 12:22 PM Thread Starter
HOODY's Avatar
not new to radios but never had one in a powerstroke, so i run a shielded wire to the battery and grounded under a bolt in the firewall, its a galaxy radio even when on low 1.5 watts i key to talk and it shutts down battery light comes on any ideas what am i missing ?
HOODY is offline
post #2 of 17 Old 01-17-2014, 01:16 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I wonder if your alt is shot? Might be worth pulling it out and getting it tested.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
HOODY (01-18-2014)
post #3 of 17 Old 01-17-2014, 01:31 PM Thread Starter
HOODY's Avatar
could be, other thread mentions an unshielded icp? i have
no clue,
HOODY is offline
post #4 of 17 Old 01-17-2014, 01:52 PM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
it its connect straight to the battery then if its getting power from somewhere else than thats the problem
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
The Following User Says Thank You to dannanw For This Useful Post:
HOODY (01-18-2014)
post #5 of 17 Old 01-17-2014, 02:12 PM Thread Starter
HOODY's Avatar
connected directly to drivers side battery, ground is to a bolt in the firewall/floor area, using 2, 4ft firesticks on mirror mounts . 2002 f250 7.3 i have hooked many radios up this way with no problem however they were not diesel so is the rf from the radio affecting the computer? would it be better if i used a whip off the back bumper?
HOODY is offline
post #6 of 17 Old 01-17-2014, 05:12 PM
miked.'s Avatar
i don't know if my problem is the same or not. i had a 95 psd and the electric brake box went bad. every time i stepped on the brake it would kill the engine. i replace the box and fixed the problem. again don't know if this will help.
miked. is offline
The Following User Says Thank You to miked. For This Useful Post:
HOODY (01-18-2014)
post #7 of 17 Old 01-17-2014, 05:55 PM
Joel's Avatar
Quoted: 10 Post(s)
Do you have a chip? Some chips are sensitive to RF frequencies.
Try re routing the antenna cable so it's a little less close to the PCM on the drivers side kick panel and see if that helps anything.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
The Following User Says Thank You to Joel For This Useful Post:
HOODY (01-18-2014)
post #8 of 17 Old 01-17-2014, 06:08 PM
gone6.0's Avatar
Quoted: 26 Post(s)
I would say if the truck starts back good it is not the alt. possibly bad connection somewhere, those Galaxy radios ROCK, have the juice.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
The Following User Says Thank You to gone6.0 For This Useful Post:
HOODY (01-18-2014)
post #9 of 17 Old 01-17-2014, 06:27 PM
Macon's Avatar
Edit; that came off mean. It's not the alt, because it dies when the radio is keyed. It's very doubtful of a bad connection, because...RF. It's likely a non-OEM, or OEM compliant, sensor/gauge/wire/something that accepts unintentional interference. It could also be an out of spec radio. A bad connection is not a likely culprit.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
The Following User Says Thank You to Macon For This Useful Post:
HOODY (01-18-2014)
post #10 of 17 Old 01-17-2014, 06:29 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Weird I have mine set up in the same way but dont have the issue you do. Something isnt right somewhere.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
The Following User Says Thank You to Im_Strokin_ur_Cummins For This Useful Post:
HOODY (01-18-2014)
