Old 10-05-2008, 04:20 PM
slowcoupe slowcoupe is offline
tapping into for boost gauge?
I did a search and still am unsure. Where are you guys tapping into for your boost gauge reading. On autometers site it shows to use the 1/4 inch T fitting into the MAP line. However some people say to drill into the intake. Dieselmanors site says you can do it that way also. Which is going to give me the most accurate reading. If i dont have to tap into my intake i dont want to.
I am installing a ITP Overboost annihalator right now will this affect my boost reading if install the T fitting into the MAP line?
Old 10-05-2008, 05:30 PM
Bushwakd Bushwakd is offline
Mine is tapped in at the Y intake.
Old 10-05-2008, 05:32 PM
cchase cchase is offline
If you arent going to run huge boost numbers like an upgraded turbo, you can put it right in the map line, just put it closer to the turbo then your boost annihalator and you will get a good reading, I can understand not wanting to drill into your inatake manifold.
Old 10-05-2008, 06:06 PM
sweet thanks alot
Old 10-06-2008, 06:32 AM
NCHornet NCHornet is offline
Powerstroke Techie
I have had mine in the map line for years with no problem. I have also never needed the boost fooler!! I will set the 1211 code but not the boost code. Reckon I don't drive her hard enough!!
NCH
Old 10-06-2008, 09:46 AM
dieselcrawler dieselcrawler is offline
Removing the air intake heater works too... that's what I did to mine, removed it, found the proper metric pipe plug, and drilled and taped the plug for the boost line fitting, 1/8" pipe if I remember... do a search, I remember listing the proper sizes in a post a while back.... this is only an option if you have a late '99 or newer truck... early '99 didn't have the AIH...
Old 10-06-2008, 09:49 AM
CHUCK CHUCK is offline
Lifetime member
map line......
Old 10-06-2008, 01:08 PM
Sweet. I got it done last night. I used a 1/4 in T fitting cut a piece of the stock map line about 3 inches put it on one side put the boost annhalator line on the other side and hooked it all up. I just didn't want to cut the Itp boost line either
Old 10-06-2008, 02:36 PM
AIH delete fitting is metric threads, I checked my old posts... 22mm x 1.5 pitch threads.
I did a search for "metric thread plug" and the bottom one listed, originated my myself, has the discription of what I did in the first post... I'm not computer saavy enough copy it to here... sevral AIH delete topics come up... check it out... good luck...
Old 10-06-2008, 02:37 PM
LOL... guess I shoulda read your post before my last one... Glad to hear you got it done!
