early 99 losing boost - any ideas? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-17-2014, 06:58 AM Thread Starter
Quoted: 3 Post(s)
I have a boost gauge in the truck - I have noticed that it reads lower then it use to when I first got the truck. At 1200 rpm it is now reading 1lb of boost instead of what I think I remember it use to read 3 to 5 lbs. This is not on the chip. Truck also takes a lot longer to kick in and move for passing then it use to.
So my question is what do I look at - Turbo broken fins, inner cooler, system tubing leaks or all the above?
Truck / motor now has 188,000 miles on it. I have also been wondering when injector service/replacement should be done?
Thanks for your help. Daryl
ToyMan is offline
post #2 of 5 Old 01-17-2014, 07:35 AM
jesilvas's Avatar
Quoted: 2 Post(s)
At idle means nothing.
You could have exhaust leaks pre turbo, which will be sooty areas by the up pipes.
Intake system could have leaks - pressurize manually and test.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 01-17-2014, 07:36 AM
alaskan155's Avatar
Quoted: 60 Post(s)
check intercooler piping boots for cracks(6 boots total) and up-pipes/manifolds. boost should be alot higher, my 02 at full throttle is up in the 20s according to my torque app i believe boost should be in the high teens to 20s for stock with the pedal fully pressed.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #4 of 5 Old 01-17-2014, 07:36 PM Thread Starter
Quoted: 3 Post(s)
Thanks I will check this out - I thought I remembered 20 or so when I first got it - when passing with ship in stock position.
ToyMan is offline
post #5 of 5 Old 01-18-2014, 06:09 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
completely stock truck max boost is about 16 psi.
you most likely have a boost leak, you can build a boost leak detector or buy one from dieselsite.
on a side note my ipr was faulty and when i replaced it i gained 3 psi of boost. it wasnt reading correct oil pressure.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
