Old 10-04-2008, 07:38 PM
RedneckGirl RedneckGirl is offline
Send a message via ICQ to RedneckGirl Send a message via Yahoo to RedneckGirl
Help a girl out here...Instrument Cluster...
Lately I have been having issues with the Ex. Still love it but am getting tired of the battery light flickering off and on. It throws no codes and the Ford house says that the cluster is bad. The Ex has been through all sorts of diagnostics and everything comes back fine time and time again.
Sooooo...here I go looking for a replacement cluster. I am having a hell of a time finding a new one. Can anyone point me in the right direction? I'd rather just do the installation myself and not pay Ford house prices. I found the white face that I will be adding to the new cluster already
Second, I did find one which was salvaged from a wrecked Ex at a decent price. They state that the Ex was wrecked it had 79,000 miles on it. Now, does the milage that is on the cluster transfer over once it is replaced? How does it work with a new one? Does the internal computer hold the milage? I'm completely lost when it comes to this!
Any help would be greatly appreciated!
Old 10-04-2008, 07:56 PM
HVAC SuperTech HVAC SuperTech is online now
Input Shaft Twister
do you have the digital odometer? if so, the mileage on the cluster will be the mileage you see on your truck. I believe thats correct.
try Ford Parts Discounted
I would alos look on ebay. you can always find stuff there thats in good shape.
It sux that a little problem can be such a pain. I know how that is. Good luck finding it!
Old 10-04-2008, 08:00 PM
Yes, I have the digital odometer
I keep on finding the clusters for the 7.3 with the analog odometer, and the one for the late 03s that was made for the 6.0s. Mine is the 2003 with the 7.3 (production prior to 11/02).
Hmm..trying to find a part number...
This has turned out to be a nightmare. I am at my wits end with the battery light. I am honestly considering disabling the light for good
Old 10-04-2008, 08:07 PM
Input Shaft Twister
yeah, might be your cheapest thing. course, cant you monitor amperage output on your outlook monitor?
Parts for the SD pickups and PSD Exs are HARD to find.
bockhold bockhold is online now
lʍǝʞs poɯ 2 oƃ ʇupıp ɔıɹǝ
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
b4 you pull the cluster out, check the connections to the alt and maybe jiggle them to see if the light goes away.
my alt light comes on and off and flickers if the single contact on top of the alt is loose. autozone checked the alt and said it failed. then checked the charge output on the batts when running and passed.
Old 10-04-2008, 08:13 PM
overo overo is offline
I had the same problem with mine. Took it to an alt. rebuilder and he said this happens all the time. He replaced one of the connections and hasn't happened since. That was 5-6 months ago.
Old 10-04-2008, 08:27 PM
95and05 95and05 is offline
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
the cluster milage is the milage you will see unless something has been changed since the last cluster change i did.
I would def check the alt wiring very well B4 changing the cluster.
Old 10-04-2008, 08:29 PM
toddy toddy is offline
OperationSmile.org
My old work truck did that all the time at higher RMPS. Eventually the alternator went out so we replaced it and I haven't seen the light since
Old 10-04-2008, 09:18 PM
krazeehorse krazeehorse is offline
Before I replaced the cluster I would yank the bulb out and put a voltmeter in.
Old 10-04-2008, 09:27 PM
you havent seen the light??????????????
