fuel leak fixed? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-15-2014, 01:03 PM Thread Starter
miked.'s Avatar
fuel leak fixed?
would there be enough fuel left in the valley under the turbo to run forward towards the filter? reason i ask is i replaced the filter drain valve and dried up what i could reach. took it for a short drive and there was fuel under the spider but not under the valve. just wandering if there was that much fuel left under the turbo.
miked. is offline
post #2 of 7 Old 01-15-2014, 01:12 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I woulda washed all of it out and not left flammable diesel on a motor longer than I had to.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 7 Old 01-15-2014, 07:32 PM
the valley really has no drain to it but there are a couple of decent "dimples" in it that fuel or oil sit in, but it can be a real pain to remove it all with everything on top of the motor. It is just a matter of patience to soak it up or like I did make suction type gun from a cheap turkey baster with a hose attached to it to reach the hard to reach place to try and get it all -- still takes patience though
hnbperformance is offline
post #4 of 7 Old 01-15-2014, 08:20 PM
Quoted: 14 Post(s)
I put some rags down in the valley and used a stick (or long screwdriver) to push them around and sop up the fuel. Worked fine.
I thought there was actually a drain hole at the back of the valley in case water got onto the engine.
ttyR2 is offline
post #5 of 7 Old 01-15-2014, 11:21 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
ive sprayed off the top of the engine a few times.
i hate working on dirty greasy oilly crap.
it will drain out the back fyi
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 7 Old 01-15-2014, 11:24 PM
Rodslinger's B1TCH
-soak the valley with a can of degreaser
-thoroughly pressure wash the valley out
-drive up a long, steep hill
steve604 is offline
post #7 of 7 Old 01-16-2014, 05:05 PM Thread Starter
miked.'s Avatar
sprayed engine off tonight with engine gunk and sprayed that off with hose. drove it till dry. will check for leak tomorrow. thanks for the input
miked. is offline
