Rear spacer help - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 01-14-2014, 07:46 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 79 Post(s)
Rear spacer help
So I have a new truck I'm working on and I have a set of 24s on it with a steel work bed I just don't like how inset the rear tires are I love the way they look I just want to space them out. So does anyone know the best safest spacers I can use to get them out 1 maybe 2 inches and what is best alluminum or steel
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #2 of 11 Old 01-14-2014, 07:55 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 79 Post(s)
If you can tell the rear tire is to far inAttachment 226538Attachment 226554
Really just looking for info and advice not looking for "I hate those rims or that's ugly or anything of that nature"
post #3 of 11 Old 01-14-2014, 08:08 PM
have to have spacers made for that distance, the best way would be to make spacers that bolt to your existing wheel studs then have a wheel stud through them in between the existing ones to attach the wheel. Have made things like this to offset drag wheels but not to this extreme usually around 3/4 of an inch mabye an inch at most
(spacer bolts to hub, has new wheel studs pressed into spacer to accept outer wheel)
WHERE THERE IS A WILL THERE IS A WAY)
hnbperformance is offline
post #4 of 11 Old 01-14-2014, 08:24 PM
kbragg430's Avatar
Wheeladapters.com call fred goetzke. He makes 2" spacers out of steel not aluminum. Pricey but the safest. 370/pair. You can get t6 aluminum spacers for probably 200 a pair.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #5 of 11 Old 01-14-2014, 08:37 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 79 Post(s)
Thanks I will check them out 370 isn't bad for a good product and I just need them on the rear I appreciate it
post #6 of 11 Old 01-14-2014, 10:42 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
high quality aluminum spacers are fine too.
just not cheap ones.
there was another thread about this not to long ago, schlutzer posted a few different websites i cant remember what they were
t-ray those rims must have been pricey when the person first bought them lol.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #7 of 11 Old 01-15-2014, 01:17 AM
schlutzer's Avatar
Quoted: 18 Post(s)
These are the aluminum ones that I posted. I've used them in the past. American made, very good quality.
We manufacture the best BORA Wheel Spacers money can buy | Motorsport Tech
The other site I posted before was Fred's which has already been suggested
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #8 of 11 Old 01-15-2014, 07:12 AM Thread Starter
t-ray-4ray's Avatar
Quoted: 79 Post(s)
Yea I have seen these rims on a few diesel trucks around here I wish they were 22s so I could get some more aggressive tires cheaper because 35s for 24s are pricey
post #9 of 11 Old 05-12-2014, 12:38 PM
7.3LDriver's Avatar
Quoted: 5 Post(s)
Sorry for bringing this post back up but what kind of load can these aluminium spacers handle? It looks like $380 for all 4.
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
post #10 of 11 Old 05-12-2014, 12:45 PM
schlutzer's Avatar
Quoted: 18 Post(s)
As for a real number I'm not sure. You're best bet is to call and ask, but in reality they will hold more than the stock cast aluminum wheels. Their website appears to be half broken at this moment... must be an update the searches arent working for me
7.3LDriver likes this.
