Manifold removal - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-14-2014, 08:34 AM Thread Starter
justinlogue5_0's Avatar
Manifold removal
I have the E99 and I am showing signs of serious rust on the manifolds around where the up pipes connect. To my knowledge everything is factory so I am wanting to replace everything with new(or like new). I know the bolts on all the up pipe stuff will have to be cut off but my worry is the bolts holding the manifolds to the head it self. Are all of these gonna break off and force me to have the heads drilled/tapped etc... or do you think these will back onout? I know its kind of a hard question to answer since no two trucks are the same. Anything I can do to help me out? Thanks for any help.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #2 of 8 Old 01-16-2014, 12:20 PM Thread Starter
Bump Anyone?
It never ends!
post #3 of 8 Old 01-16-2014, 12:29 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
bp blaster for 2-3 days and pray...and have a heli coil ready
if they're not leaking then rust is normal as they're cast iron and take ALOT of heat.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 8 Old 01-16-2014, 12:36 PM Thread Starter
Surpriseingly enough I have not seen any signs of leaking. I just know its a matter of time and am dreading it.
It never ends!
post #5 of 8 Old 01-16-2014, 12:43 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
yea, the oil pan is another one that is a pain too...but if your worried about it I'd buy a set and have them ready. just my
dannanw is offline
post #6 of 8 Old 01-16-2014, 12:49 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I think you are worried about nothing.... the manifolds are really thick. Only failures I've personally seen on them are where they expand and break the bolts on #7 cylinder from excessive high EGT's.
I don't think I would attempt to remove them unless I had the engine on a stand... to me it's not worth it, especially if they arent leaking
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #7 of 8 Old 01-16-2014, 12:51 PM Thread Starter
I have a good (used) set of manifold. Now I got to get some up pipes and wait for the day. Getting droke bolts out a head is only thing that scares me. If something can go wrong,its gonna go wrong with me.
It never ends!
post #8 of 8 Old 01-16-2014, 12:53 PM Thread Starter
I won't fix it till it breaks, I just like to be ready when it does.
It never ends!
