looking for good shocks - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-20-2006, 05:44 PM Thread Starter
AZ2001F-350's Avatar
ok guys my tire question was answered on someone elses post so my guestion is what is a good shock to run.i have p.o.s rancho 5000 on currently but they are ready for the trash. i have been looking at procomp mx6. what does everyone recommened. my truck has a 8" lift
2001 f-350 8" lift 35" pro-comp tires tri pillar gauges 18k mod running biodiesel 6637 mod 5"exhaust stright pipe,ts chip,bdp stageII spiltshot injectors,scan-guage and triple disk t/c
AZ2001F-350 is offline
post #2 of 5 Old 11-20-2006, 06:09 PM
Ranch96's Avatar
I like the bilstein's that I got. They don't have a remote resovoir or anything, but they seem to handle good. Only gripe is they are a little on the firm side.
01 Dodge 3500 24v
Silencer ring MIA, BHAF, straight piped lots more to come
old truck......02 F250 4wd DP,BTS,BD,AFE...... :burnout
Ranch96 is offline
post #3 of 5 Old 11-24-2006, 04:18 PM Thread Starter
mx6 shocks
does anybody have the procomp mx6 shocks. how do you like them
post #4 of 5 Old 11-29-2006, 10:06 AM
I'm running the fabtech dirt logix with remote res and love em. little on the pricey side, but I think they're worth it as they're completely rebuildable. do you have dual shocks up front/in back? i've run pro-comp's on my jeep and other trucks in the past and you get what you pay for. I would recommend the rancho 9000's, bilsteins, or fabtechs. fox also makes shocks for 8' lifted SD's, but they're a little more $$ than the fabtech's and they're basically the same shock/design/technology. also, what type of driving? off-road much? my fabtech's really helped the ride in the back of the truck on the freeway, I live in cali and the freeways are garbage. if you're looking for a quick fix and don't want to spend the $$, buy the pro-comps, but they will likely be clapped out in a year and you'll spend that $$ again.
2002 F-350 Crew Cab 7.3L Turbo Diesel. 8-inch lift/38-inch Parnelli Jones Dirt Gripz/4.56 Gears F & R/Mag-HyTek Pans & Covers/SC Programmer/AFE Intake/5.5 Exhaust/WARN Hubs/Pod with really nifty glow in the dark gauges/blah/blah/blah/more stuff on the garage floor
Joe44 is offline
post #5 of 5 Old 11-29-2006, 04:46 PM
FatManStroke's Avatar
Send a message via MSN to FatManStroke Send a message via Yahoo to FatManStroke
if you can afford them i agree with the bilstein 5150's shock's with resevoir. they will last longer due to the res and probably ride alot better. some of the others cant remember which are the same shock even built in the same factory. rancho and monroe are like that if i remeber correct i believe procomp is one as well.
"Darker Than Your Average Wheeler"
97 F250 PSD 4X4
AFE 4" Turbo Back Exhaust.
AFE CAI.
TonyWildman chip. Thanks Tony!!!
Gauges Boost/EGT/ Fuel Pres
86 Bronco II
Whats left of it!!
FatManStroke is offline
