AE question for the gurus - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-13-2014, 02:40 PM Thread Starter
russtwentyfour's Avatar
Just put an adrenaline hpop on last week so broke out the ae to see what numbers I was getting currently. Just need some help deciphering them since for the life of me I could not find a baseline to compare them too. Do here they are:
At idle, chip turned to stock with fresh oil, good and hot(just drove home from work),
Oil temp 163f
Icp= 480
Duty cycle= 10.16
Icp volts= .82
Inj pulse width= .21
Are these numbers good?
Went for test drive on freeway ran wide open for a ways, here's the numbers
Icp= 2400 plus or minus 50 best was 2501 but only for a second
Duty cycle= 35.94 hit 36.33 but never higher
Icp volts= 3.03-3.39
Inj pulse width= .23-.25
Seems to me I should have a higher duty cycle and higher pressures with a new hpop, Icp sensor, and ipr all ford parts minus the hpop of course.
On a side note I turned my TS chip to race and here's the numbers for that
Icp= 2339
Duty cycle= 37.5
Icp volts= 5.5 but had a spike at 12.8
Ipw= .54
Please help me make sense of all these numbers
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #2 of 2 Old 01-14-2014, 04:51 PM Thread Starter
Come on guys anybody wanna help a brotha out?
Mbrp 4" turbo back
Ww2
Afe rear end cover
