stalls when you take it out of park - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-13-2014, 09:48 AM Thread Starter
The truck stalls when you take it out of park! Any idea why it would do this?
waterdr is offline
post #2 of 3 Old 07-09-2014, 03:17 PM
heykw's Avatar
What was the fix?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 3 Old 07-09-2014, 06:05 PM
alaskan155's Avatar
Quoted: 60 Post(s)
last time i had a truck do that, it was a bad torque converter/lock up solenoid. that was stuck locked, was a 90 5.0 with the e40d.... ended up cutting a wire and got it working, but it was a beater truck.... (paid $500 for it)..
is the ecm throwing any codes/ OD light flashing? if you get it rolling in nuetral, can you start it and drop it into drive and keep moving, and if so, does it die when you stop(probably shake the cab and die) is so start looking into the plug on the trans(and wiring)/ the lockup solenoid on the trans..
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
