P0221 Throttle / Pedal Position Sensor - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-13-2014, 08:44 AM Thread Starter
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 16 Post(s)
This code came up when running a routine AE check. No SES light and no symptoms other than a harder than usual startup over the past month. Any suggestions?
Is it just a sensor or do I have to replace the entire pedal assembly?
Its a 03 Ex
410,000 miles
PHP Hydra Mishimoto Radiator
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #2 of 2 Old 01-13-2014, 08:47 AM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
just the sensor (have also seen wire/pig tail issues too), I'd clean the contacts good thought just to try before replacing...also ohm the GP system too
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
