Tire pressure....
912 views 6 replies 4 participants last post by  LOW96HB
I am asking a qurestion that i'm sure has been covered before. I am having front tire wear problems. Alignment is good, no worn or damaged parts...So what tire pressure should I be running? I know its a big heavy truck, and 4 wheel drives are known for ffont tire wear but this is worse than normal...
Any suggestions?
The wear is on the outer edges inside & outside. I am currently rinning 50 psi in the front and 50 in the rear. I work this truck as well as part time daily driver...
im at 55psi front and rear. nitto trail grapplers, not too much heavy hauling.
