I am asking a qurestion that i'm sure has been covered before. I am having front tire wear problems. Alignment is good, no worn or damaged parts...So what tire pressure should I be running? I know its a big heavy truck, and 4 wheel drives are known for ffont tire wear but this is worse than normal...
Any suggestions?
The wear is on the outer edges inside & outside. I am currently rinning 50 psi in the front and 50 in the rear. I work this truck as well as part time daily driver...
im at 55psi front and rear. nitto trail grapplers, not too much heavy hauling.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
