Interior LEDs. Help please. - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Ford Cowboy
post #1 of 9 Old 01-12-2014, 12:51 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Ok installed a strip of LEDs on the driver and passenger side foot wells. Was gonna wire them to come on when I turn on the interior dome lights. I pulled the headlight switch and started testing wires to see which one powers the interior dome lights. I can't find it. Identified the dimmer though. When you roll the dimmer switch all the way into the up position it turns on the dome lights. Which freakin wire is it?? Nice Sunday afternoon project hahaha. Thanks for any help
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 9 Old 01-12-2014, 01:57 PM Thread Starter
Quoted: 5 Post(s)
Anybody? Kinda at a stand still
post #3 of 9 Old 01-12-2014, 05:08 PM Thread Starter
Quoted: 5 Post(s)
Nobody has a clue???
post #4 of 9 Old 01-12-2014, 06:14 PM
codyryan07's Avatar
I couldn't tell ya right off, was hoping you had found a solution.. I was thinking about doing the same thing, but was going to tap into one of the wire for the dome lights.. hope it works out for you though..
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #5 of 9 Old 01-12-2014, 06:45 PM Thread Starter
Quoted: 5 Post(s)
I haven't found $h!t yet. Trust me I've searched f$$&in everywhere. I found an old post where somebody was doin something similar and ended up spliceing into a Blue wire with black runner that was behind driver kick panel. Haven't verified that yet though. I'm thinking I'm gonna have to splice into an overhead dome light and run a wire from there. So much for bein simple.
post #6 of 9 Old 01-12-2014, 06:49 PM
7.3pwrstrke's Avatar
Find the wire to the lights in the door. You know that little reflector towards the back of the door? Well that light also turns on with the dome lights.
Edit:
This reflector, you could pop the door panel off find the wire color and find the positive lead in the kick panel of the truck.
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #7 of 9 Old 01-12-2014, 10:26 PM
F350Bigfoot's Avatar
Or you could look under the inner fender well behind the plastic for an open triangular looking plug that is for the running board lights. Post some pics up as I am looking into doing this. But I want them to come on when headlights do and be running lights and have a white set for door openings.
F350Bigfoot is offline
post #8 of 9 Old 01-14-2014, 04:29 PM Thread Starter
Quoted: 5 Post(s)
Ok y'all got this figured out! First off, thanks to Rammstein1224 for the help. Keep in mind my truck is a 2000 and I don't know if wire colors changed from year to year. I highly doubt they did change. Remove your drivers side kick panel. Behind that panel is a small bundle of wires. Now, I was told to look for a blue wire with a black tracer. I found none. What I did find was two black wires with thin blue tracers. So, I crossed my fingers and spliced into one of the wires. We now have power. The lights now come on when you unlock truck with key fob, open the doors, or turn interior dome lights on. Don't think it matters which one of the wires you splice into seein as how it wouldn't make sense that two wires of the same color/tracers would power two separate devices (in this case lights). Pretty cool if you ask me. Probably gonna add some to the back at some point. Hope this helps anybody wantin to do something like this.
peter379 likes this.
post #9 of 9 Old 02-16-2014, 10:20 PM
StrokinAlaska's Avatar
Black/Lt blue in driver kick panel small gauge wire
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
