Lpop question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-12-2014, 08:47 AM Thread Starter
Lpop question
Need a little help, my truck when cranking to start doesn't build oil pressure. When it kick off and runs for a few seconds then the oil pressure builds and it runs fine. It's better now I went to synthetic but if it doesn't catch right runs the hpop out of oil and becomes a pain to refill and start. Is that my lpop going bad or something else need to look at?
Rstar is offline
post #2 of 7 Old 01-12-2014, 09:07 AM
scagle1's Avatar
Sounds like a possibilty of worn gears on LPOP if HPOP isnt being filled , Front cover could also be scarred letting oil seep back down. you really need to get LPOP readings to confirm it's reliabilty and move forward from there.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 7 Old 01-12-2014, 09:10 AM Thread Starter
Thanks. I have an edge insight and the oil pressure numbers. What should they be when at idle?
Rstar is offline
post #4 of 7 Old 01-12-2014, 11:50 AM
scagle1's Avatar
10 psi at idle , 40-70 at 3300. Does the insight monitor low pressure #'s ?
scagle1 is offline
post #5 of 7 Old 01-12-2014, 11:56 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Actually its more like 50psi at idle and up to 100 when revving
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 7 Old 01-12-2014, 12:03 PM
Chapter Director
Quoted: 5 Post(s)
This will help diagnosis the LPOP Diagnosing a 7.3 no start
Just read the part about hpop reservoir
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 7 Old 01-13-2014, 07:24 AM Thread Starter
Thanks for the help, it's getting a little aggravating when starting the truck.
Rstar is offline
