Water leak in cab - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-11-2014, 07:59 AM Thread Starter
Cummins_Killer's Avatar
Water leak in cab
Hey guys, i have a water leak somewhere in my passanger floor. Im pretty sure its coming from underneath beacuse the carpet is soaked underneath the floormat. It dosent look like its running down the fire wall, also underneath the plastic doorjamb trim piece was filled with water. I was thinking of getting flex seal and spraying the passanger side floor, but id like to see what you guys have to say.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-Diamond Eye 4" Turbo Back Straight Pipe
-33" Nitto Trail Grapplers on 18" XD Diesel
-2.8" Leveling Kit
Cummins_Killer is offline
post #2 of 12 Old 01-11-2014, 08:48 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
I'd take a close look at the lower corners of where the Windshield is on both sides. It's not an uncommon area for leaks. You can take some Talc and "puff" it up there, then keep an eye on it for signs that the first signs of the origin of a leak...
NoRalPh is offline
post #3 of 12 Old 01-11-2014, 08:59 AM
Texas Proud
charlie.thomas's Avatar
I've read a post similar to this a few months back that someone else had this problem and if I remember right it was from the air blower assembly that traps water some how and ends up leaking since there is no drain on it and they drill a hole at the bottom of it somewhere under the hood. Do a search in the forums and I'm sure you could find it. My does it but it's from my sunroof leaking the pillar.
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #4 of 12 Old 01-11-2014, 11:22 AM
Quoted: 176 Post(s)
Originally Posted by charlie.thomas View Post
I've read a post similar to this a few months back that someone else had this problem and if I remember right it was from the air blower assembly that traps water some how and ends up leaking since there is no drain on it and they drill a hole at the bottom of it somewhere under the hood. Do a search in the forums and I'm sure you could find it..
This happens in the Summer though.... The "water some how" being there is actually condensate from the AC Evaporator and not likely to be the cause today
You Do want to be sure it's water, coolant can leak from there if the Heater Core is leaking.
NoRalPh is offline
post #5 of 12 Old 01-12-2014, 08:57 AM Thread Starter
I pulled the carpet up and there were a few seams and stuff butt no major signs, im spraying everything with flex seal real good and seeing if that helps, theres no signs of the water coming from above.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #6 of 12 Old 01-12-2014, 06:32 PM Thread Starter
Well after further inspection i removed the pillar trim piece and noticed water where the windshield meets the cab, i then noticed on the outside that the window trim was not overlapping the door trim like on the drivers side, so i fixed the trim all up, put some silicone on some gaps, and now i still have the trim on the inside removed to see if i can get a better look at it when it rains(suppose to in the next few days).
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #7 of 12 Old 01-13-2014, 06:39 AM
Quoted: 176 Post(s)
You shouldn't have to wait for rain, get out the Garden Hose
NoRalPh is offline
post #8 of 12 Old 01-13-2014, 07:49 AM
Quoted: 3 Post(s)
This wouldn't work for mine when it was leaking.
Call a windshield repair company and tell them you need your windshield resealed due to a leak. It's most likely the top right side of your windshield leaking. It's a very common issue and an easy fix. I paid $65
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #9 of 12 Old 01-13-2014, 08:41 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
didn't see this till now but I agree with this...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 12 Old 01-15-2014, 10:23 AM Thread Starter
Well, its not the windshield, they suggested the cablights or the third brake light any other suggestions?
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
