truck upside down for 1 hour - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-19-2006, 07:59 AM Thread Starter
lifetime member
is my engine hurt? what do i need to do if i get it from insurance company after they total it? other info about wreck is under[ totaled, landed upsidedown] post
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #2 of 5 Old 11-19-2006, 08:05 AM
the engine is probably ok if it didnt run long upside down. As long as the bearings didnt get starved and it didnt "run away" when the oil got slung to the topside of the motor i wouldnt think the motor was hurt.
mschn99 is offline
post #3 of 5 Old 11-19-2006, 08:15 AM Thread Starter
lifetime member
marc, thanks for the reply. it all happened so fast, but i think the fuel pump shut off activated. when i crawled out the truck was upside down, radio playing, but no engine running. what about impact shaking the engine?
post #4 of 5 Old 11-19-2006, 08:18 AM
if it didnt run too long, i would let it sit (im assuming it will take some time to buy it back anyway) so everything drains down. I would be very carefull trying to start it, in fact pulling the glow plugs and bumping it over just to be safe might be a good idea. There is the possibility of oil getting into the cylenders. The only thing that will hurt is if you try to start it with the oil still in there. Bump it over with the glow plugs out, then put them back in. I would also change the oil to be safe. I dont see where anything else should have been damaged
mschn99 is offline
post #5 of 5 Old 11-19-2006, 08:53 AM Thread Starter
lifetime member
if i do get it back, i will have to take the truck apart to salvage what i want to use. i have pictures on a flash card, but don't know how to post them.
