Old 09-11-2008, 10:20 PM
FordCowboy FordCowboy is offline
Bouncing idle
I haven't checked to see if I have any codes coming up or not, but at idle in drive and park, my rpms will bounce up and down a few hundred. It has never gone below 500 at least not much, and it will go down for a second and back up to normal and then back down, and back up. A few times the truck has kinda chugged a bit and had me worried. Kind of seems like a vacuum leak of some sort, but thought I would see what kind of thoughts you guys had.
Old 09-12-2008, 10:22 AM
Anybody have any ideas
Old 09-12-2008, 12:19 PM
NCHornet NCHornet is offline
Powerstroke Techie
Has the Check engine light ever come on? I would check the UVC harness first. Check both sides, pull them apart and look for any burnt or loose connections.
NCH
Old 09-12-2008, 07:10 PM
thelittle289 thelittle289 is offline
I was told that if at start up you have erratic idle its most likely a wire harness problem. I was also told that if your truck is acting funny and there are no code coming up the cam senser could be the problem.
Old 09-12-2008, 07:16 PM
sldghamr sldghamr is offline
i have had similar problems. check out your IDM or ICP sensor.
