Exhaust bung for ccv mod - Ford Powerstroke Diesel Forum
Old 11-15-2006, 01:17 PM
<<---"Shadow"---
Who sells an exhaust bung for the ccv mod. I did the mod today and I have the 3/4 tubing pointing down just behind the back bumper out of site. I didnt realize the amount of " fumes and smoke " that would come out of the tubing. I am going to re route and put in an exhaust bung and get rid of the fumes, etc. that way.Thanks!
Old 11-15-2006, 04:38 PM
if you do that wont you get blue smoke from the oil in the exhaust? let me know how it comes out...jason
Old 11-15-2006, 04:42 PM
you could use a header evac setup used in drag cars, it comes with a check valve so the fumes from the engine crankcase only go one way ..out the exhaust and does not let exhaust into your crankcase jegs or summit has them. they are intende fro drag cars though i dont know how well they will hold up for extended use............jason
Old 11-15-2006, 04:43 PM
you could use a header evac setup used in drag cars, it comes with a check valve so the fumes from the engine crankcase only go one way ..out the exhaust and does not let exhaust into your crankcase. jegs or summit has them, they are intende fro drag cars though i dont know how well they will hold up for extended use............jason
