Old 09-11-2008, 07:01 PM
mratop mratop is offline
Head Lights
Im looking to replace the head lights on my 99 F350, its time! the lenses are glazing over and not as bright as they should be. Any suggestions?
Old 09-11-2008, 07:04 PM
DCSpecial DCSpecial is offline
Supporting Vendor
I'd swap in some 05-07 headlamp assemblies.
Just have to cut the header panel and get a wiring harness to install them.
Old 09-11-2008, 07:05 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
this is one of the best things can do....
their is a write up somewhere on this forum with exact pictures of where you have to cut the header panel
the conversion harness is only 30 bucks...
Old 09-11-2008, 07:13 PM
Thanks for the tips I will try and find that post. Are there any good aftermarket lights that I can just plug in and go or should I stick with factory?
Old 09-11-2008, 07:15 PM
you could always just get OEM like the ones you have that are new....
but if it were me i would stick with OEM
-Raul
Old 09-12-2008, 12:34 PM
NCHornet NCHornet is offline
Powerstroke Techie
Anything other than OEM will probably leak. I replaced mine with the clear 2003 headlights, you can see pics in my sig. I did this back in 2003 and made a huge improvement. I also installed the upgraded GOS harness to my lamps get more power.
NCH
Old 09-12-2008, 07:26 PM
sttstroke sttstroke is offline
Just take aluminum polish and clean them, you'll be amazed at how much better they look.
Old 09-12-2008, 08:41 PM
Jerryjust Jerryjust is offline
MrAtop!!
I tried some cleanser and warm water rub all over lenses just like rubbing compound after clean real good and spray lenses with wifes hair spray let dry, and enjoy. Worked for me lasted 8 months.
jerryjust
Old 09-13-2008, 08:03 AM
caryt caryt is offline
Best headlight housings as far as light output possibilities is the clear 03-04. get factory or pro car's from Ebay. Then install Hella's harness with their 80-100w 4k Kelvin bulbs. Install their new Halogen Infra Red bulbs in the factory fogs and mod the switch to allow use with the high beams.
Don't install any headlight that uses a 9008-h13 blub..crap. The H13 is quite possibly the stupidest design for a bulb ever foisted on the public. The terminals are so small that they overheat, even at stock wattages, and melt the plastic housing of the connectors. Higher than stock wattage bulbs are offered, but not recommended .
Cary
Old 09-13-2008, 09:43 AM
Cary
istead of doing all that wiring why not just switch to HID bulbs? they would be brighter and use up less power
