  #11 (permalink)
Old 05-29-2007, 11:23 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Originally Posted by saca93 View Post
I'm getting a loud noise from under the floor when i leave from a stop. you can feel it in your feet any toughts?
Check your front end, ball joints, brake calipers, rotors, wheel bearings, tie rods, hubs, something is loose.
  #12 (permalink)
Old 05-29-2007, 12:09 PM
saca93 saca93 is offline
did all that already evertthing is tight sounds like its coming from trans area
but trans mount seems to be ok
  #13 (permalink)
Old 05-29-2007, 12:43 PM
lilredpowerstroke lilredpowerstroke is offline
Did you check the sway bar bushings or end link bushings?
  #14 (permalink)
Old 05-29-2007, 12:48 PM
2005F250 2005F250 is offline
I have a work truck that has had the start up thump for 40K miles now and it has not caused any problems.
  #15 (permalink)
Old 05-29-2007, 01:30 PM
bluestroker bluestroker is offline
Tournaments Won: 1
I get a thump in my front end when i lock it in 4wd and turn is that normal
  #16 (permalink)
Old 05-29-2007, 05:24 PM
Dave Dave is online now
Obama sucks
i will bet on that
  #17 (permalink)
Old 05-30-2007, 07:37 AM
everything looks ok its just when i leave from a stop and if i dont ease on the gas it dose it, and its like a bang under the truck. i cant find and thing loose or broken but i noticed that the rear axle has alot of axle rap when you hit the gas is this normal?
  #18 (permalink)
Old 05-30-2007, 07:09 PM
Obama sucks
did you check your u joints
