  #11 (permalink)
Old 09-08-2008, 05:15 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
how much boost you pushing?
  #12 (permalink)
Old 09-08-2008, 06:00 PM
Dave Dave is online now
Vikings cheerleaders YUM!
Originally Posted by Raul@Stealth Automotive View Post
your temps dont seem too far off.... i used the granatellie fuego and hated it... it always ran very hot....
do you have an exhaust and intake done? that will help lower the egt's
-Raul
800 degrees at idle is pretty hot IMO
  #13 (permalink)
Old 09-08-2008, 08:27 PM
bryanbrown bryanbrown is offline
I'm thinking everybody missed that part. there's has to be something wrong with the guage, though 1175 on a hard pull doesn't sound bad. When you say 800 at startup, what exactly do you mean? After sitting all night, or cruising down the highway?
  #14 (permalink)
Old 09-08-2008, 10:30 PM
RMP750 RMP750 is offline
After sitting all night and with a ambient temp of about 65 degrees.
On a hard acceleration the boost gauge reads arounf 7 to 8 psi then back down to around three max at 1800 to 2000 rpms on the freeway.
  #15 (permalink)
Old 09-09-2008, 04:23 AM
2003_F250_FX4 2003_F250_FX4 is offline
My EGT's on start up are only 230F, Normal driving mine is in the 500F, Pulling 14,000lbs @ 75mpg it is in the 850-950F, A hard pull with no load 1200F
  #16 (permalink)
Old 09-09-2008, 07:59 AM
superduty4x4 superduty4x4 is offline
You should be getting more boost under hard acceleration, but your cruising boost sounds good. My truck runs about 600 on the pyro when warmed up cruising 65 mph/1800 rpm at 3 lbs boost.
  #17 (permalink)
Old 09-09-2008, 08:01 AM
floored from a dead stop you should see about 10 psi stock more tuned
  #18 (permalink)
Old 09-09-2008, 08:05 AM
Redfox0099 Redfox0099 is offline
7.3L pullin a 7.0L S/C
Really...only 10 PSI is what we should see stock, I thought someone said 35 PSI stock...
(sorry, I am a Diesel noob...if I am wrong please inform me)
  #19 (permalink)
Old 09-09-2008, 08:31 AM
no way you would see 35psi stock.... 20 psi maybe..... anything over 28psi and your doing more bad then good with a stock turbo....
-Raul
  #20 (permalink)
Old 09-09-2008, 09:05 AM
I will try that out at lunch today. I really want to get by egt's lower but not sure how.
