  #11 (permalink)
Old 09-11-2008, 06:13 AM
tubular031 tubular031 is offline
Originally Posted by MM Billetworks View Post
Any comparisons between straight pipe and the walker muffler with respect to sound? Does running a straight pipe really increase sounds inside the cab - resonating or no real noticeable difference inside the cab - running straight pipe?
What about a hangar for the Walker muffler? Did not see one?
I was running mine with the pipe ending right after the cab (cause I pulled off the muffler) and I liked the sound of the straight pipe, but the rest of the clan did not like it and we were only running empty, start pulling something and it would get even louder! I was out voted....
I have not put a hanger on the BTM yet. I was going to cut one off the old muffler and then have my budy weld it on. Have not seen him in a while. Its not too big of a deal since its pretty solid down there and there are 3 or 4 hangers in front of the muffler and 1 behind it. its solid.
Originally Posted by NCHornet View Post
I can hear the difference, straight pipe is louder, I prefer the BTM, the only time I hear the flutter is when I drive near a tall building or large wall when in the city, which isn't often. Then I roll down the window as I like the sound. Before you straight pipe, just know it won't be long before all diesels will be required to pass emissions testing. First part of test is a visual, no muffler, you fail. I hope all those who removed their CAT's saved them!!
NCH
I can hear mine with the window down when I am light on the throttle. but when I take off hard I dont hear it unless there is some thing next to me to reflect the sound (truck, fence, building...) but even with the windows up, hit 3k rpm and full boost, sounds like a jet engine back there! (but not too bad) then roll the windows down, hit 3k next to a fence or something else, and wow it sounds crazy! its hard to get a vid of that since usually at 3k rpm there is way too much wind noise and it kills the vid....
  #12 (permalink)
Old 09-11-2008, 07:46 AM
MM Billetworks MM Billetworks is offline
Walker
I went ahead and put the Walker muffler on this morning. Slightly lower exhaust note at idle. There is a slight drone in the cab with windows up between 1500-1700 rpm -not bad.
I ended up using a 5" O.D. stainless tip for the 3.5" stock exhaust. Looks pretty good.
Thanks for the responses!
  #13 (permalink)
Old 09-11-2008, 07:57 AM
I have not noticed any drone with the windows up. do you have a short cab and a short bed maybe? maybe you are closer to the tail pipe then I am?
  #14 (permalink)
Old 09-11-2008, 08:22 AM
I have 4x4 4-door dually long bed. The drone I hear is very slight at those rpm's. Not a problem for me as it is so slight. To me, this still qualifies as a "quiet" exhaust mod. I do play more with custom super charged/big inch V-twin motorcycles, so this thing still purs like a kitten! LOL
Thought I would add that we welded hangars to the weld joints on the Walker - front and back to minimize any stress.
  #15 (permalink)
Old 09-20-2008, 08:25 PM
greenie greenie is offline
Walker Big truck muffler
Originally Posted by tubular031 View Post
Yup NC, you were one of the reasions I went this route along with Strokin making 450+ hp with a 3.5 dp. The output of the turbo is only 2.5 inches if I remember right so 3.5 is plently. like you say, put a garden hose in a 6 inch pipe, you will not flow anymore.
Q:I have an early 99,is the down pipe 2.5.Is that stock?
Did you remove the cat?
What is the stock pipe 2-3" all the way to the tail?
%:If I need to go 3.5 from the turbo to the tail,i'll be replacing the whole system.Is their a savings this way or going to a 4" system?
Thanks, ultra flow mufflers sounds good.
  #16 (permalink)
Old 09-21-2008, 09:13 AM
I dont know much about the early 99s. on mine (late 99 to 03) its 3.5 inches all the way back (including the DP) the 2.5 inches is the exhaust housing. I am not sure on the 2.5 inches, but I know its less then the DP size. If strokin early does not chime in, I would PM him, he knows alot about the early 99s.
  #17 (permalink)
Old 09-21-2008, 09:54 AM
blowinsmoke4life blowinsmoke4life is offline
Send a message via AIM to blowinsmoke4life
sounds great
  #18 (permalink)
Old 09-21-2008, 02:26 PM
NCHornet NCHornet is offline
Powerstroke Techie
There wasn't a change is exhaust size from 99-99.5, I believe the down pipe is 3" and the exhaust 3.5"
NCH
  #19 (permalink)
Old 09-22-2008, 01:57 PM
Highbeam Highbeam is offline
I agree, there is a bump up to 3.5" pipe right near the transmission on my 2000. Appears to be 3" to the turbo.
  #20 (permalink)
Old 09-22-2008, 02:10 PM
TxPSD9673 TxPSD9673 is offline
you dont need an insanely big dp unless your runnin 500-600+ hp but the upgrade from a 3.5 inch system to a 4 inch system IS alot better trust me egts will drop even more, sound will be even deeper and better. mainly cus the bump in diameter, and mainly bc of all the sharp bends in the factory exhaust. just look at a pic of a 4'' aftermarket system on the ground next to a removed factory system. remember im talking about the system not the dp. 3-3.5'' dp is more than enough for most of us
