Old 09-03-2008, 07:56 PM
bigred_stroker bigred_stroker is offline
Digital Display / Gauges ????
I need to get some gauges in my truck and was originally wanting to buy / install an edge insight untill I realized that they dont make them for an 02 7.3L. Does anyone know of a digital display monitor that would take the place of gauges? The only reason that I am looking for a digital display is because it would be nice to display 4 parameters at once and have the capability of reading codes too. But I am not really interested in buying one that has programs because my plans are to get a DP tuner and really am not interested in stacking. Anyhow, any advice would be appriciated. Thanks
By the way, I am looking for something that can read out the EGT's, Boost, and probably Trans temp too.
Old 09-03-2008, 08:00 PM
southern7.3 southern7.3 is offline
Powerstroke Fanatic
BullyDog makes an outlook monitor and quadzilla makes one also. Hit up shane (sea71) he has the quadzilla and you could talk to him about it
Old 09-03-2008, 08:02 PM
2005F250 2005F250 is offline
You could always buy a used edge programmer for cheap and just use it for the gauges. You don't need to run the edge tunes to make the gauges work. I was gonna do this untill I found out about the MSD dashhawk. Got the dashhawk instead.
Old 09-03-2008, 08:03 PM
shu873 shu873 is offline
hillbilly keyboard racer
I've got the quad commander. It'll do everything you want it to and then some.
Old 09-03-2008, 08:04 PM
huhner5 huhner5 is offline
Commander works great for me too.... super clean look with the pillar mount
Old 09-03-2008, 08:20 PM
Dave Dave is offline
Obama sucks
Commander works good BD X monitor also works good
Old 09-03-2008, 09:21 PM
Motown Fire Motown Fire is offline
Howmuch $$$ did the Quad Commander and the BD X Monitor run???
Old 09-03-2008, 09:26 PM
ford_trck ford_trck is offline
I blame the dog
Send a message via AIM to ford_trck
I have the TS performance MPD. It doesn't have a trans temp spot put it does egt, fuel pressure, boost, and RPM's
Old 09-03-2008, 09:41 PM
2003_F250_FX4 2003_F250_FX4 is offline
I love my Quad Display, I have it hooked up to a TS 6-pos chip, nice to be able to change your tune on the same device.
Old 09-04-2008, 12:00 AM
sirnunya sirnunya is offline
how do you hook up a ts chip switch to a commander?
