Old 12-28-2005, 02:04 AM
dieselfitter dieselfitter is offline
Talking Veggie oil
I see alot of info on these vegetable oil converstions, do they work? What problems do they cause? Seems like a cheap way to operate your vehicle if it works. The one I researched is Frybird out of Seattle.
Old 12-28-2005, 03:39 AM
Rodslinger Rodslinger is offline
Gun Nut
Welcome to Powerstroke.org dieselfitter!
Check out this thread it's got some info on vegtable diesel...
http://www.powerstrokeforum.com/foru...read.php?t=593
Old 12-28-2005, 07:32 AM
Veggie-Destroyer Veggie-Destroyer is offline
Cool u need mo info?
check out greasel .com greasecar.com o yea and plantdrive . i had a site but friends to cheap to pay bills .the last guy i met had a system he made himself . when i asked who kit did he buy he said walmart 119$ on an older mb. you gotta think if your car is 3k and frybrid is 2 k it dont make sence . but if you have a 26k car you dont spend 119 at walmart . go for it and match the system to the vehical .do the reasearch because the stinky stealerships will be scared of a pioneer like you gl
my cam p sensor went out over the holidays
Old 12-28-2005, 02:09 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Grammar Police Chief
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Hey Veggie did you happen to have an extra cam sensor when it happened, or did you have to wait for a parts store to open? They like to fail at the best of times don't they?
Old 12-28-2005, 03:52 PM
ok it came guess what
ok yea to get it at 80 i had to wait since the 23rd but guess what i learned!!!
ok i swapped it out still nuthen cranked for days
but nuthen
i read here about the fuel presure relief valve and though a quick test might be to block off my fuel returns .vice grips awayyyyy
HOT dam vroom voom . it lives so i reved it a few times then took off the vice grips and listen to it slow loose it vroon then die O
i guess i didnt need the cam sensor but the code did come up on my predator tuner?? and at least i know where it goes
so why cant i run the system without a return ??
dont give no sht about temp viscosity lubrication .just will it kill my aeromotive pump .or how do i replace the fuel pressure valve and stretch the spring e .
THANK YOU ALL WHO POST HERE I HAVE LEARNED A LOT I GOt more glow plug ??? 2 ill start newthread
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
