Old 09-02-2008, 03:11 PM
bigcountrysg bigcountrysg is online now
duct tape & zip ties
Vin Number
Will the vin number indentify what injector code I have. I know I can just pull the valve covers and look. But if I can use the vin number that is a lot simplier.
Old 09-02-2008, 03:24 PM
Dirk Dirk is offline
Diesel Innovations
Being an 02, I'm 99% sure you have AD's and the AE in the #8 hole.
Old 09-02-2008, 03:47 PM
Well the #8 is the one that is bad. After talking to numerous people including Scuffy thanks for the info earlier over the phone. I think for now being money is tight. I have a hook up on some rebuilt injectors. Being that no one can beat this deal I am going to take my chances with this hook up. I just needed to know what injector code I needed. I really didn't feel like taking the valve cover back off to look. ( I know I should have looked when I did the glowplugs)
Old 09-02-2008, 03:57 PM
Diesel Innovations
Just take the 30 min to pull the cover and put it back on.
Old 09-02-2008, 07:01 PM
CSIPSD CSIPSD is offline
You have AD's... there was nothing else put in in 01-02-03's...
Old 09-02-2008, 07:03 PM
How much money would you put on that statement.
Old 09-02-2008, 07:05 PM
If there the stock injectors, $100... AE will be in #8... If they have been swapped you could have some AB selonoids on there, but rest assured they are AD 140cc injectors.
Old 09-02-2008, 07:11 PM
Stock Original Injectors. I had one fail at the dealership. I have a hook up for one injector. I just didn't want to pull my valve cover to look. The bad one just happens to be #8.
Old 09-02-2008, 07:13 PM
The bad one will be an AE if its in #8... but put an AD in and you will be fine, might pick up a bit of ICP and HP from it...
Old 09-02-2008, 07:17 PM
Diesel Innovations
How many times did they test the injectors? I've seen a number 8 fail just for the hell of it.
