Old 09-01-2008, 01:42 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Stage 1 Injectors
Ok well if I need new injectors. I have decided I will get Stage 1s. Now besides having my chip reburned what else would I need to do to support the injecotrs.
All my mods are in my signature.
Old 09-01-2008, 01:45 PM
Tikal Tikal is offline
Thas how we do'r in Dixie
Send a message via AIM to Tikal
Shouldn't need anything...Your truck already has a 17* HPOP...that's the only problem a person could get into
Like mine, with the 15* pump, if I stay in it hard on more aggressive tunes it'll start cuttin' out.
Your SD has everything to support it...
Only thing I could think would interfere would be if u changed to single shot...I dunno if Tony can make the chip tell the computer it has single shots...
Old 09-01-2008, 01:46 PM
cchase cchase is offline
for stage ones, you wouldnt have to do anything besdies the chip, you've got the intake exhaust and gauge. maybe a torque converter, and deeper pan in your futre,
Jon
Tournaments Won: 1
Posts: n/a
Well
I think you ought to jump on the next budget build. Big oil, injectors, fuel system, bottom end, no2, trans, the works. I think you can do it for about $2000. Its been done right here on this site before.
Old 09-01-2008, 01:51 PM
I think I will stick with injectors for now Jon. My trans is pretty solid. I still have to have it for a DD truck.
I just don't see a reason to go with stock replacement injectors when stage 1s are not that much more.
Now if I did decide to go with single shots what would I need to do. I understand that stage 1 split shots are pretty much a drop in thing. So what about single shots. I know they spray differently.
Old 09-01-2008, 02:22 PM
they are drop in, just need to do the chip.
and how do you get all that for 2 grand jon? thats seems way low...
Old 09-01-2008, 03:45 PM
CUMMINS_KILLA99 CUMMINS_KILLA99 is offline
i was thinking the same thing maybe if half of it is stolen and the other half is used lol
Old 09-01-2008, 03:52 PM
rankroddin250 rankroddin250 is offline
if you go with split shots you wont have to do any thing. if you go with single shots the truck wont even run with out tuning.
Old 09-01-2008, 04:12 PM
strokin_early_99 strokin_early_99 is online now
John Wood Nut Swinger
Wrong! The truck will run. It will run like crap up until around 2300-2400rpm and the throttle will be touchy as all get out but it will run. Hell, I ran my setup on a stock PCM for a couple of days to see how it ran. Alabamafrog ran his truck on stock tuning and even towed with it while his chip was out getting reprogrammed so it has been done.
Old 09-01-2008, 04:40 PM
Well I think for simplicity of things I will end up going with stage 1 split shots. That way if something happens like my chip takes a dump or something. I can just go ahead and drive the truck with out having any issues. As this is my daily driver.
