Need help ASAP - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-10-2006, 03:10 PM Thread Starter
Powerestroker2000rt's Avatar
Need help ASAP
Hey guys
my truck started freakin out this afternoon. I was driving off from a stop sign and got on her a bit, not floorboarded about 3/4. Then cruized up to about 45, then maintained, but a few minutes later, it dropped in rpms to 500 then surged to 1000 and went back and forth for a few seconds before shutting off. i pulled over turned the key off. turned it back on and started just fine. drove it to the autoparts store to see if it threw any codes. it didnt, but it drives fine as long as i dont accelerate hard. Any ideas
Powerestroker2000rt is offline
post #2 of 15 Old 11-10-2006, 03:23 PM
Raul@Stealth Automotive's Avatar
maybe the cps? mine did that after i got it a few years back.....
Raul@Stealth Automotive is offline
post #3 of 15 Old 11-10-2006, 03:33 PM
The Fat Mod
Logan's Avatar
Yeah, thats my first thoughts, CPS, you may have to pay full price, or take it to ford and pay the $100. It will be cheaper that way. Then once you get it fixed, Get you a spare. I know they sell them on ebay for pretty cheap.
Logan is offline
post #4 of 15 Old 11-10-2006, 03:33 PM Thread Starter
would
would that have thrown some kind of code though. Cause the service engine soon light flashed the whole time it was freakin out, but then just went off and didnt come back on.
post #5 of 15 Old 11-10-2006, 04:29 PM
Powerstroke Techie
djsdiesel's Avatar
If the check engine light came on it should have stored a code. But like they said it is most likely the cps. I dont know what kind of code reader was used but from my expierience the cheap ones that are sold at autoparts stores arne't very good. I bought a mac mentor and i've pulled codes out of vehicles that a cheap wouldn't pull
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #6 of 15 Old 11-10-2006, 06:13 PM Thread Starter
Thanks Guys
Well i can honestly say im glad i use this forum cause my truck now runs again. I mean my butt hurts from the raping autoz0ne gave me but atleast i can go hunting in the morning. ive had this truck 10 days and ive already learned the lesson of needing to keep a spare cps on hand
post #7 of 15 Old 11-10-2006, 06:20 PM
<<---"Shadow"---
sea71's Avatar
Glad youre rollin!! Get the spare!!
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #8 of 15 Old 11-10-2006, 06:30 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Make sure
your spare is a Ford one to replace the autozone one when it goes out.
post #9 of 15 Old 11-10-2006, 06:43 PM
lanny251's Avatar
i would buy only OEM cps sensors!!! I just had to send two aftermarket ones back to carquest the would start to die out at about 2000 rpms but would work fine at lower rpms...put an OEM one in and had no more problems!!!
lanny
lanny251 is offline
post #10 of 15 Old 11-10-2006, 06:49 PM
Powerstroke Techie
djsdiesel's Avatar
if you have an international dealer around they are cheaper there than at ford
