PowerSteering pulley loose? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-17-2008, 08:07 AM Thread Starter
I've been getting this strange noise when decelerating and braking in my truck, coming from the front end. The sound is also present when idling.
I popped the hood and let the truck idle, trying to find the location of the sound.
It appears it's coming from somewhere on the serpentine belt. I used one of my Dad's tools and took the tension off the serpentine belt and felt each pulley. All of them are locked up tight with no play except the Power steering pulley.
Is there supposed to be lots of play in that particular pulley? The sound does appear to be coming from that side of the engine block.... Can anyone relate?
Joe1911 is offline
post #2 of 5 Old 08-17-2008, 08:12 AM
Other vehicle is an F250
Hank's Avatar
There souldn't be ANY play in ANY pulley. Get it fixed immediately. When you loose the PS pump you also loose your brake assist. May be a real surprise when the power steering and the power brakes let you down at the same time. You won't loose all your brakes, but it could be a hand full depending on the situation. Get one on there today if you can.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 5 Old 08-17-2008, 08:48 AM
I agree it is a pump or a line and I had mine go and you do not want to wait even a day get it fixed asap
penderman5 is offline
post #4 of 5 Old 01-30-2009, 12:35 PM
hpf350's Avatar
I just realized I may be having the same issue. The pulley for my power steering pump can wiggle back and forth. And the serpentine belt makes a horrible hissing sound as if it were worn but the belt is good and all the other pulleys are tight. Does the whole pump need replaced or can I just tighten the pulley? I noticed in my CHilton manual I need a special tool to remove and install a pump. Should I buy this tool to try and tighten the pump? What is the tool and do you think I can get it at Sears or Harbor Freight Tools?
All help is needed!!!
2001 F350 Lariat CC LB 4x4
Protected by RanchHand
4" Exhaust
Lifted with FAT tires
Rancho Suspension
AGR Steering Gearbox
Stancor Relay Mod
COMING SOON!!!
HHO Generator
DIY Intake
AGR Power Steering Pump
CD Receiver and Speakers
New shocks and Brakes!!!
hpf350 is offline
post #5 of 5 Old 01-31-2009, 04:51 AM
hpf350's Avatar
BUMP...any tech on the org want to chime in here please?
4" Exhaust
Rancho Suspension
Stancor Relay Mod
COMING SOON!!!
HHO Generator
DIY Intake
hpf350 is offline
