Just curious - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-08-2006, 05:22 PM Thread Starter
payne5757's Avatar
Just curious
Ive never had anyone specifically explain to me why diesels make the little squeak when u shutem off. Anyone have a technical explanation? Just trivial knowledge I like to know. Thanks in advance.
2000 Ford F250 Super Duty Powerstroke ( 7,460lbs 5in rough country lift, 18in XD Revolvers, 35in Dura Grapplers, bilsteins all around, 4in.MBRPstraight pipe,WW,TS 6 pos chip,TS Monitor w/HUD,Tymar,map fooler,foil delete, zoodad, Kenwood stereo, pioneer 6x8s, JL 500V1 amp, and one JL12w7)
payne5757 is offline
post #2 of 7 Old 11-08-2006, 05:59 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Little squeek?
Um, probably the turbo winding down but mine doesn't squeek exactly...
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 7 Old 11-10-2006, 08:40 AM
Talking
It is the compression of the diesel motor stopping the crank from turning immediatly, with everything else still turning (all the pulleys) so you'll get a little squeak from the belt on the crank pulley when you shut it off. Hope this explains it for you.
firefighter56 is offline
post #4 of 7 Old 11-10-2006, 08:46 AM
<<---"Shadow"---
sea71's Avatar
Its the hampster that runs in the cage under the hood beepbeepbeepbeepbeepin at you cause you made him stop running!!
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #5 of 7 Old 11-10-2006, 10:18 AM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
only in powerstrokes.....lol
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #6 of 7 Old 11-10-2006, 02:48 PM Thread Starter
payne5757's Avatar
Originally Posted by CHenry View Post
Little squeek?
Surely youve heard it on semis and other diesels before. Ive heard it on alot of motors.
post #7 of 7 Old 11-10-2006, 02:49 PM
I havent' heard it on mine, but my buddy's truck same year/engine does it.
