2002 7.3 Completely Dead - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-07-2006, 07:27 AM Thread Starter
We have an '02 F-550 w/7.3 PSD that just up and died while it was running. The mechanic here (if you can call him that!) tried to get it to fire on starting fluid, but no go (seemingly no compression). He believes that the cam or timing gears is wiped out.
The motor has something like 120,000 miles on it. I haven't heard of people having timing problems with these motors. Is this something common?
If any of the techs look in on this one, I would be interested in your diagnosis or list of common causes of these symptoms.
Thanks!
720Deere is offline
post #2 of 5 Old 11-07-2006, 09:48 AM Thread Starter
Anybody?
Bump, bump!
720Deere is offline
post #3 of 5 Old 11-07-2006, 09:50 AM
Raul@Stealth Automotive's Avatar
maybe the cps? its a common problem with 7.3... only would cost you around 50 bucks so it wouldnt hurt to try....
Raul@Stealth Automotive is offline
post #4 of 5 Old 11-07-2006, 09:54 AM Thread Starter
Thanks! We already talked about the CPS but as I said before they tried ether on it and it doesn't fire. A failed CPS won't prevent it from firing on starting fluid.
I agree with you. I would at least try a CPS. It's not like we don't have five or six other trucks around here to use it on if it doesn't work!
720Deere is offline
post #5 of 5 Old 11-07-2006, 10:09 AM
House22's Avatar
Send a message via AIM to House22
looks for the ecm fues and see if its blown, i bet the fuel heater broke and blew the fues, if its blown, unplug the fuel heater on back of the fuel filer housing, install new fues and start also look and see if tach moves and oil pressure goes up
2000 F350 Crew Cab Dually Larait all options
zf6 6 speed
SBC 4200 Full Fermaic DD Clutch
Custom Tunning by Swamps
Swamps 355 Injs
Itp Diesel Reg Return, Hi Po Delivery Kit
Aeromotive a1000 fuel pump
BTS Twin HPOP, Arp Head Studs, Di Pushrods, Comp 910's, Fluid Damper
Hypermax Mount Turbo Mount
S476 By Swamps BFH-HE
One piece rear drive shaft by haisley machine
Ntpa certifed Drive line shields done by Haisley machine
House22 is offline
