  #11 (permalink)
Old 08-08-2008, 12:30 PM
Send a message via AIM to blizzardwarrior7
Oh sorry, didn't realize you were new. Here is a video, of someone installing the 10k resistor mod.....You could go ahead and try doing this mod if you want at the same time....But you will see where it is from the video...Simply unplug it....And drive around, if the problem cleared up, you have a bad icp sensor, if its still doing it....Than its something else, and you should plug your sensor back in.
99-03 7.3L 10K resistor mod - VIDEO!
  #12 (permalink)
Old 08-08-2008, 12:35 PM
i will try that later tonight and get back with you uys thanks alot.
  #13 (permalink)
Old 08-08-2008, 02:55 PM
unplugged it still nothing now took it to the dealer he said buzz test was good and no codes. he said could be fuel pressure does the pressure from the pump go up the faster you go.could it be the screens in the tank or not why would it only do it when you hammer on it. thanks
  #14 (permalink)
Old 08-08-2008, 02:58 PM
Wow, no codes?.....The pressure actually drops at WOT....I guess that would be a thing to check as well, if your fuel pressure is dropping too much at WOT than it may display symptoms like you are describing.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
